PC Board Serial Number
5 REPLIES 5
JTJSBJB
1767 Views, 5 Replies
Hi everybody,
I've been using AutoCAD since AotuCAD R12, Since then I'm writing autolisp programme for my own use. I've 1 small problem. I don't know the AutoCAD command on how to extract the 9 digit of PCB serial number. The purpose for this is to protect the program it self. I hope somebody can give me the answer. Thank you
Mamy.
5 REPLIES 5
cado
in reply to: JTJSBJB
Hi..
You can use the HD serial number..
(defun HDSERIAL (drv / DrvObj FSO getDRV)
(setq FSO (vlax-create-object "Scripting.FileSystemObject"))
(setq getDRV (vlax-invoke FSO 'GetDrive drv))
(vlax-get getDRV 'SerialNumber)
  (vlax-release-object FSO)
  (vlax-release-object getDRV)
JTJSBJB
in reply to: cado
Hi Mr. CADO,
Thanks a lot for your reply on my message and helping me to solve the problem.
I've tried the small lisp that posted by you. Unfortunately it's not work. Maybe my AutoCAD version is not competable with the command.
cado
sorry....I forgot to put...
 (vl-load-com)
JTJSBJB
Hi Mr. CADO,
It's give me error as below. I've tried for every line in the lisp.
; error: too few arguments
cado
ok I see...
you need to specify your drive.
examples..
(vl-load-com)
;|    TESTS
(HDSERIAL "c:")
(HDSERIAL "x:")
(HDSERIAL "\\\\Server1\\folderA\\FolderB")
put the (vla-load-com) on the top.
”Boost
