• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Valued Contributor
    msarqui
    Accepted Solution
    Outline projection all viewports to model
    291 Views, 8 Replies
    12-07-2011 08:30 PM
    Hey guys!
    Is there a lisp for automatically draw a pline in model space of the projection of all existing paper space viewports, without need to select one by one?
    It will be also interesting if the lisp automatically create a specific layer like "ProjectViewport" to draw this plines.
    I am working with autocad 2009.
    Thanks for your help!
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: Outline projection all viewports to model
    12-07-2011 08:38 PM in reply to: msarqui
    Hi .
    May I ask what do you mean by project viewport ?
    Valued Contributor
    msarqui
    12-07-2011 08:58 PM in reply to: _Tharwat
    I mean to create a pline in modelspace that has the outline of all viewports in the drawing.
    Something like the attached lisp, but automaticaly in "one shot".
    alanjt_
    12-08-2011 11:46 AM in reply to: msarqui
    This works for me... (thanks to gile for the transformation routine)
    (defun c:VPO (/ _trans _cornersFromBBox ss i ent data ent2 lst)
      ;; Viewport Outline
      ;; Require subroutine: PCS2WCS (and all subs it requires)
      ;; PCS2WCS by gile (http://www.theswamp.org/index.php?topic=29231.msg347755#msg347755)
      ;; Alan J. Thompson, 12.08.11
    (vl-load-com)
      (defun _trans (p) (cons 10 (PCS2WCS p ent))) (defun _cornersFromBBox (o / a b) (vla-getboundingbox o 'a 'b) (setq a (_trans (vlax-safearray->list a)) b (_trans (vlax-safearray->list b)) ) (list a (list (car a) (cadr a) (caddr b)) b (list (car b) (cadr b) (caddr a))) ) (if (setq ss (ssget '((0 . "VIEWPORT")))) (repeat (setq i (sslength ss)) (setq ent (ssname ss (setq i (1- i))) data (entget ent) ) (if (if (setq ent2 (cdr (assoc 340 data))) (setq lst (apply 'append (mapcar '(lambda (x) (if (eq (car x) 10) (list (_trans (cdr x))) ) ) (entget ent2) ) ) ) (setq lst (_cornersFromBBox (vlax-ename->vla-object ent))) ) (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)) '(70 . 1) '(410 . "Model") ) lst ) ) ) ) ) (princ) ) ;; WCS2PCS (gile) ;; Translates a point WCS coordinates to the PaperSpace CS according to ;; the specified Viewport ;; ;; (WCS2PCS pt vp) is the same as (trans (trans pt 0 2) 2 3) when vp is active ;; ;; Arguments ;; pt : a point ;; vp : the viewport (ename or vla-object) (defun WCS2PCS (pt vp / elst ang nor scl mat) (vl-load-com) (and (= (type vp) 'VLA-OBJECT) (setq vp (vlax-vla-object->ename vp)) ) (setq pt (trans pt 0 0) elst (entget vp) ang (cdr (assoc 51 elst)) nor (cdr (assoc 16 elst)) scl (/ (cdr (assoc 41 elst)) (cdr (assoc 45 elst))) mat (mxm (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) (mapcar (function (lambda (v) (trans v nor 0 T))) '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0)) ) ) ) (mapcar '+ (vxs (mxv mat (mapcar '- pt (cdr (assoc 17 elst)))) scl) (vxs (cdr (assoc 12 elst)) (- scl)) (cdr (assoc 10 elst)) ) ) ;; PCS2WCS (gile) ;; Translates a point PaperSpace coordinates to WCS coordinates ;; according to the specified viewport ;; ;; (PCS2WCS pt vp) is the same as (trans (trans pt 3 2) 2 0) when vp is active ;; ;; Arguments ;; pt : a point ;; vp : the viewport (ename or vla-object) (defun PCS2WCS (pt vp / ang nor scl mat) (vl-load-com) (and (= (type vp) 'VLA-OBJECT) (setq vp (vlax-vla-object->ename vp)) ) (setq pt (trans pt 0 0) elst (entget vp) ang (- (cdr (assoc 51 elst))) nor (cdr (assoc 16 elst)) scl (/ (cdr (assoc 45 elst)) (cdr (assoc 41 elst))) mat (mxm (mapcar (function (lambda (v) (trans v 0 nor T))) '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0)) ) (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) ) ) (mapcar '+ (mxv mat (mapcar '+ (vxs pt scl) (vxs (cdr (assoc 10 elst)) (- scl)) (cdr (assoc 12 elst)) ) ) (cdr (assoc 17 elst)) ) ) ;; VXS Multiply a vector by a scalar ;; ;; Arguments : a vector and a real (defun vxs (v s) (mapcar (function (lambda (x) (* x s))) v)) ;; VXV (gile) ;; Returns the dot product of two vectors (real) ;; ;; Arguments : two vectors ;; return : a real number (defun vxv (v1 v2) (apply '+ (mapcar '* v1 v2))) ;; TRP ;; transposes a matrix -Doug Wilson- ;; ;; Argument : a matrix ;; return : a matrix (defun trp (m) (apply 'mapcar (cons 'list m))) ;; MXV ;; Applies a transformation matrix to a vector -Vladimir Nesterovsky- ;; ;; Arguments : une matrice et un vecteur ;; return : a vector (defun mxv (m v) (mapcar '(lambda (r) (vxv r v)) m) ) ;; MXM ;; Multiplies (combinates) two matrices -Vladimir Nesterovsky- ;; ;; Arguments : deux matrices ;; return : a matrix (defun mxm (m q) (mapcar '(lambda (r) (mxv (trp q) r)) m) )
    Valued Contributor
    msarqui
    12-09-2011 09:39 AM in reply to: alanjt_
    Hi alanjt_
    This routine is pretty amazing.
    It is exactly what I was looking for.
    Thank you very very much!
    Marcelo
    alanjt_
    12-09-2011 10:27 AM in reply to: msarqui
    Glad you like it. :smileyhappy:
    When it prompts to select viewports, if you type "AL" or "ALL", it will drawn the border for all viewports in the drawing.
    *Expert Elite*
    12-10-2011 01:08 AM in reply to: alanjt_
    Nice coding Alanjt
    Cheers
    alanjt_
    12-10-2011 08:15 AM in reply to: msarqui
    Thanks, but gile transformation code was the bulk of the acutal work. :smileyhappy:
    New Member
    10-16-2012 05:50 AM in reply to: alanjt_
    The  vp-outline.lsp is very good.
    There exist some updates to work with circular viewports?
    Best regards
