Hey guys!
Is there a lisp for automatically draw a pline in model space of the projection of all existing paper space viewports, without need to select one by one?
It will be also interesting if the lisp automatically create a specific layer like "ProjectViewport" to draw this plines.
I am working with autocad 2009.
Thanks for your help!
Solved by alanjt_. Go to Solution.
I mean to create a pline in modelspace that has the outline of all viewports in the drawing.
Something like the attached lisp, but automaticaly in "one shot".
This works for me... (thanks to gile for the transformation routine)
(defun c:VPO (/ _trans _cornersFromBBox ss i ent data ent2 lst) ;; Viewport Outline ;; Require subroutine: PCS2WCS (and all subs it requires) ;; PCS2WCS by gile (http://www.theswamp.org/index.php?topic=29231.msg347755#msg347755) ;; Alan J. Thompson, 12.08.11
(vl-load-com)
(defun _trans (p) (cons 10 (PCS2WCS p ent))) (defun _cornersFromBBox (o / a b) (vla-getboundingbox o 'a 'b) (setq a (_trans (vlax-safearray->list a)) b (_trans (vlax-safearray->list b)) ) (list a (list (car a) (cadr a) (caddr b)) b (list (car b) (cadr b) (caddr a))) ) (if (setq ss (ssget '((0 . "VIEWPORT")))) (repeat (setq i (sslength ss)) (setq ent (ssname ss (setq i (1- i))) data (entget ent) ) (if (if (setq ent2 (cdr (assoc 340 data))) (setq lst (apply 'append (mapcar '(lambda (x) (if (eq (car x) 10) (list (_trans (cdr x))) ) ) (entget ent2) ) ) ) (setq lst (_cornersFromBBox (vlax-ename->vla-object ent))) ) (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)) '(70 . 1) '(410 . "Model") ) lst ) ) ) ) ) (princ) ) ;; WCS2PCS (gile) ;; Translates a point WCS coordinates to the PaperSpace CS according to ;; the specified Viewport ;; ;; (WCS2PCS pt vp) is the same as (trans (trans pt 0 2) 2 3) when vp is active ;; ;; Arguments ;; pt : a point ;; vp : the viewport (ename or vla-object) (defun WCS2PCS (pt vp / elst ang nor scl mat) (vl-load-com) (and (= (type vp) 'VLA-OBJECT) (setq vp (vlax-vla-object->ename vp)) ) (setq pt (trans pt 0 0) elst (entget vp) ang (cdr (assoc 51 elst)) nor (cdr (assoc 16 elst)) scl (/ (cdr (assoc 41 elst)) (cdr (assoc 45 elst))) mat (mxm (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) (mapcar (function (lambda (v) (trans v nor 0 T))) '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0)) ) ) ) (mapcar '+ (vxs (mxv mat (mapcar '- pt (cdr (assoc 17 elst)))) scl) (vxs (cdr (assoc 12 elst)) (- scl)) (cdr (assoc 10 elst)) ) ) ;; PCS2WCS (gile) ;; Translates a point PaperSpace coordinates to WCS coordinates ;; according to the specified viewport ;; ;; (PCS2WCS pt vp) is the same as (trans (trans pt 3 2) 2 0) when vp is active ;; ;; Arguments ;; pt : a point ;; vp : the viewport (ename or vla-object) (defun PCS2WCS (pt vp / ang nor scl mat) (vl-load-com) (and (= (type vp) 'VLA-OBJECT) (setq vp (vlax-vla-object->ename vp)) ) (setq pt (trans pt 0 0) elst (entget vp) ang (- (cdr (assoc 51 elst))) nor (cdr (assoc 16 elst)) scl (/ (cdr (assoc 45 elst)) (cdr (assoc 41 elst))) mat (mxm (mapcar (function (lambda (v) (trans v 0 nor T))) '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0)) ) (list (list (cos ang) (- (sin ang)) 0.0) (list (sin ang) (cos ang) 0.0) '(0.0 0.0 1.0) ) ) ) (mapcar '+ (mxv mat (mapcar '+ (vxs pt scl) (vxs (cdr (assoc 10 elst)) (- scl)) (cdr (assoc 12 elst)) ) ) (cdr (assoc 17 elst)) ) ) ;; VXS Multiply a vector by a scalar ;; ;; Arguments : a vector and a real (defun vxs (v s) (mapcar (function (lambda (x) (* x s))) v)) ;; VXV (gile) ;; Returns the dot product of two vectors (real) ;; ;; Arguments : two vectors ;; return : a real number (defun vxv (v1 v2) (apply '+ (mapcar '* v1 v2))) ;; TRP ;; transposes a matrix -Doug Wilson- ;; ;; Argument : a matrix ;; return : a matrix (defun trp (m) (apply 'mapcar (cons 'list m))) ;; MXV ;; Applies a transformation matrix to a vector -Vladimir Nesterovsky- ;; ;; Arguments : une matrice et un vecteur ;; return : a vector (defun mxv (m v) (mapcar '(lambda (r) (vxv r v)) m) ) ;; MXM ;; Multiplies (combinates) two matrices -Vladimir Nesterovsky- ;; ;; Arguments : deux matrices ;; return : a matrix (defun mxm (m q) (mapcar '(lambda (r) (mxv (trp q) r)) m) )
Hi alanjt_
This routine is pretty amazing.
It is exactly what I was looking for.
Thank you very very much!
Marcelo
Glad you like it. 🙂
When it prompts to select viewports, if you type "AL" or "ALL", it will drawn the border for all viewports in the drawing.
