Visual LISP, AutoLISP and General Customization
Osmode Bit that toggles off the running snaps...
4 REPLIES 4
mdhutchinson
754 Views, 4 Replies
What is the osmode bit that toggles off the running snaps... but leaves the underlying user running snaps settings un-effected?
4 REPLIES 4
pbejse
in reply to: mdhutchinson
Not sure ...  16384
Kent1Cooper
Yes, it's 16384 [it's right there in Help for the OSMODE System Variable].  The following is effectively the same as hitting F3 to toggle running Osnap on or off [whatever it isn't currently] without changing the combination of modes:
(setvar 'osmode (boole 6 (getvar 'osmode) 16384))
Kent Cooper, AIA
mdhutchinson
Thanks!  That is exactly what I needed.
Kent1Cooper
You're welcome.  I didn't look, since I knew a quickie answer, but I suspect the same question has come up here before....
Kent Cooper, AIA
”Boost
