Hi Laurie,
You are on the right track I think...as any drawing on that U drive IS, in
fact Read Only...
I will have to get deeper into this I think.
DP
"Laurie Comerford" wrote in message
news:44DA8FB2B35E6FF9C94D7AB2AACD78A6@in.WebX.maYIadrTaRb...
> Hi David,
> An AutoCAD toolbar icon simply runs a script. Hence, all you need do is
> carefully duplicate the keystrokes you would type from the Keyboard to
> achieve the result you require. Simply replace the use of the key
> with semi-colons ";" but without the inverted commas.
> However, in this case there is a further difficulty in that the drawing
may
> be read-only which requires a different number of keystrokes. Hence you
> will need a program to detect if the file is read only and proceed
> accordingly.
> Here's a little extract from the help files on VBA
> Sub Example_ReadOnly()
> ' This example shows if current drawing file is read only or not
> If ThisDrawing.ReadOnly Then
> MsgBox "The current drawing file is read only.", , "ReadOnly
> Example"
> Else
> MsgBox "The current drawing file is read-write.", , "ReadOnly
> Example"
> End If
> End Sub-- Laurie ComerfordCADAppswww.cadapps.com.au"David Penney"
> wrote in message
> news:056FDA3D7622D421DD77C2D5A1C77D97@in.WebX.maYIadrTaRb...
> > Hi all,
> > I have been checking google newsgroups trying to find a lisp or script
> that
> > I can use with a user-made toolbar button to open a certain drawing file
> in
> > AutoCad....
> > In all the posts I have read over the past 3 days, I have yet to see a
> > complete and constant answer to the "opening a drawing" question.
> > The drawing I want to open is say "XOX.dwg" on
> > U:\Standard Drawings\Standard AA\Folder B1\
> > What would I write either as a lisp or as a script/macro to open this
> > drawing....even if it is READ only, etc.?
> > I am totally non-plussed with this one...
> > Any help with this would be appreciated
> > (BTW: SDI = 0 on normal settings)
> > Regards,
> > DP
