Hi everyone,
I'm trying create a LISP to customize PDF creation. The lisp looks into the .PC3 file which paper size better fits the plot area. But its exaustive to every time i want to create a new paper size i have to open the .pc3 file and configure a new paper.
There is a way to open the .pc3 properties through lisp?
Thanks in advance
Netto
Solved by dmfrazier. Go to Solution.
Solved by bhull1985. Go to Solution.
It seems there is no way to read a .pc3 file with lisp and obtain useful information, I found some information and a .NET program here: CTB Viewer.
Gaston Nunez
Unfortunately I couldn't open CTB Viewer. I'm not registered in http://www.theswamp.org and it looks like they are not accepting new members at the moment.
But I don't want to obtain useful information from a Pc3 file. I just want to open its properties, like the properties option in the plot command.
Thanks anyway for your time Gasty
I believe it's
mark@theswamp.org
that you'd send an email to and he will give you an account.
as far as i remember he got back to me within an hr or two of me sending him that email
theswamp is a great place, it's probably worth sending the email to get an account there 🙂
And hey check out this portion of code, it may be of use for you. This is a defun that changes the ctb file of a dwg.
(defun c:mcp ()
(vl-load-com)
(vla-put-StyleSheet
(vla-get-ActiveLayout
(vla-get-ActiveDocument (vlax-get-acad-object))
"monochromeP.ctb" ;;<--we still use CTB, yours would be hmc-std.stb
Thank you Bhull.
I've already sent an email to mark@theswamp.org. I hope he reply soon.
Thank you as well for your routine. It helps but I've already use a cod to set plot style.
Cheers
Paper sizes don't change, so there's no real need to programmatically read a PC3 or anything special. Just note the common sizes in use, write them down in an Excel file or whatever for future reference.
I do not think I explained myself properly.
I Don't want to progammatically read a .PC3 file. I just want to open its properties via lisp.
The thing is, every time that i want to create a new paper size in DWG To PDF.Pc3 file, I've to:
Go to the path C:\Users\*user*\AppData\Roaming\Autodesk\AutoCAD 2013 - English\R19.0\enu\Plotters
Open the DWG To PDF.pc3 file.
Select Device and Documents Settings tab.
Try looking into the "startapp" lisp function.
"The thing is, every time that i want to create a new paper size in DWG To PDF.Pc3 file, I've to:
Open the DWG To PDF.pc3 file."
Why not just click "Plotter Manager"? Set the above path as your Printer Config Search Path, and it takes you right there.
I've tried to use the starapp funtion but with no success.
(STARTAPP "pc3exe.exe" "MyPath/MyPrinter.PC3") is what i was looking for.
Thank you Bhull for all your help.
Thak you dmfrazier for your soluction.
