Hi, I'm thinking about Lisp, which by one click turns one end of dimension (closer to the click) into an arrow (Open 30) and cancel the corresponding extension line ...
I tried to find some.. That I would edit, but I did not succeed. This kind of entity I never worked with, seems like to complicated to me..
Thanks for you help.
Solved by Kent1Cooper. Go to Solution.
I tried to find some.. That I would edit, but I did not succeed. .....
Since you're willing to try editing something, try this. It toggles the nearer extension line to whatever state it's not currently in, and to do that, it has a way of determining which end you're nearer, whether you pick on the extension line, the dimension line, the arrowhead, or the text. You should be able to apply that determination in assigning a different arrowhead. [The Cadalyst CAD Tips site also has several other Tips that toggle extension lines, so you can compare different approaches if you like.]
Thanks, that was easier than I thought. Thus up to DIMSAH - it took a while. 🙂
