Distinguished Contributor lai
lai
Message 1 of 14 (633 Views)
One button changing text base point to be "Middle Center"
633 Views, 13 Replies
08-23-2011 10:04 PM
Hi, wonder if anyone know how to make a toolbar button so that when i click it and select a few single text, it will automatic change the text base point to be at "MIDDLE CENTER"....
At the moment, i use to create a button with macro of  " ^C^C_text;j;mc "....But the problem is whenever i use this button, i still need to type "MC" at the command prompt.. Any idea how to make it so that after i click the button, all i need to to is just select the text..
Lee_Mac
Message 2 of 14 (621 Views)
Re: One button changing text base point to be "Middle Center"
08-24-2011 02:11 AM in reply to: lai
If you are looking to change the justification of EXISTING text, try using the TJUST command.
If you want a macro for creating NEW Text with MC Justification, try:
^C^C_.dtext;_j;_mc;
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
lai
Message 3 of 14 (619 Views)
08-24-2011 02:30 AM in reply to: Lee_Mac
Well, actually i thought of creating a button that will automatic change selected text to be at Middle Center...If to use the text justification command, i still need to type "MC" after select text that need to be rejustify.
pbejse
Message 4 of 14 (613 Views)
08-24-2011 02:51 AM in reply to: lai
^C^Cselect \Tjust previous ;mc;
BTW; you can still use this
^C^C_Tjust;mc; :
IF you select the entities with grips (note: pickfirst value 1) then click the button
lai
Message 5 of 14 (602 Views)
08-24-2011 03:23 AM in reply to: pbejse
Thanks for the help.. i am more prever with this macro "  ^C^Cselect \Tjust previous ;mc;  "
lai
Message 6 of 14 (520 Views)
03-21-2012 11:40 PM in reply to: lai
hi pbejse,
Just wonder if can modify abit on this matter.
At current, if i select text first and then use the macro, the text base point won't change..i wish to modify it so that either i click the text or macro first also can change the text base point.any possible? Please advise.
pbejse
Message 7 of 14 (510 Views)
03-22-2012 01:33 AM in reply to: lai
lai wrote:
hi pbejse,
I'm not sure if it can be done as simple as we had it before,
Tjust is already a lisp code (R 2009 that is).
You could try this
^C^C(if (setq ss (cadr (ssgetfirst)))(command "_select" ss "")(command "_select")) \Tjust previous ;mc
HTH
lai
Message 8 of 14 (507 Views)
03-22-2012 01:39 AM in reply to: pbejse
Well, i just give it a try..guess still the same as before...think need to stick to activate the macro first,then only can select text..Cause i always tend to select the text first before click the macro button.
pbejse
Message 9 of 14 (505 Views)
03-22-2012 01:48 AM in reply to: lai
Worked fo me here Lai
check pickfirst value.. should be 1
lai
Message 10 of 14 (481 Views)
03-22-2012 08:22 PM in reply to: pbejse
Hi, i have try and check the pickfirst value is equal to 1..then i try again with your command, still need me to select the text first, else will give me error as i attach..
You are not logged in.
Ask the Community
