Visual LISP, AutoLISP and General Customization
ObjectARX -> How to get attribute information from inserted block
2 REPLIES 2
479 Views, 2 Replies
I know how to insert a block with attribute information, but having trouble
to do it reversely.
I tried the following codes, Is it in right track? What is wrong and what to
do next?
Very appreciated for your help!
Joe
void CTest::GetAttribute(ads_name ent) {
AcDbObjectId id;
acdbGetObjectId(id, ent);
AcDbEntity *pEnt;
acdbOpenObject(pEnt, id, AcDb::kForRead);
if ((CString)pEnt->isA()->name() == "AcDbBlockReference") {
AcDbBlockReference *pBR;
pBR = AcDbBlockReference::cast(pEnt); // error -> undefined
AcDbBlockReference
AcDbObjectIterator *pI;
pI = pBR->attributeIterator();
pBR->close();
for (pI->start(); !pI->done(); pI->step()) {
delete pI;
2 REPLIES 2
If I understand correctly, you want to select a block and then get to the attribute tag...Maybe try using acedNEntSelP or acedEntSel
retCode = acedEntSel("\nPick the Block:", ent, Pt)
switch(retCode)
acdbGetObjectId(eid, ent);
acdbOpenAcDbEntity(pEnt, eId, AcDb::kForRead);
//cast to see if its a block
//then create a attribute iterator
I am currently fighting with this and trying to get it to work...hope this is kind of what you are looking for.
jason
Thanks. I figured it out,
size=2>no cast is needed.
Check the following code, it
works!
Joe
switch(retCode)
CTest *myTest =  new
CTest;
CString tagValue = myTest->GetAttribute(eid, "Tag:");
face=Arial size=2>...
// input -> block id and attribute tag
fileld
// output -> attribute tag value
CString CTest::GetAttribute(AcDbObjectId id,
CString ta) {
 acdbOpenObject(pBR, id,
AcDb::kForRead);
 AcDbObjectIterator *it;
 it =
 pBR->close();
 AcDbAttribute *pA;
 CString s1,
s2;
 for (it->start(); !it->done(); it->step()) {
acdbOpenObject(pA, it->objectId(), AcDb::kForRead);
  s1 =
pA->tag();
  if (s1 == ta)
   s2 =
pA->textString();
  pA->close();
 delete
it;
 return s2;
If
switch(retCode)
AcDb::kForRead);
//then create a
attribute iterator
jason
”Boost
