• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Object Selection based on type/layer
    159 Views, 1 Replies
    05-04-2010 04:53 PM
    Hi LISP guys!
    I need your help for creating a code to select some objects based on it's type and layer, just like the QuickSelect command... there are two cases:
    1. I want to select all the objects in the layer "X" an then apply a command;
    2. I want to select all the lines (for example) in the layer "Y" an then apply a command;
    and I need these action to be cumulative... execute action various times (each one with different parameters...)
    Can someone help me with a code?
    Thanks'
    Fernando
    Please use plain text.
    Distinguished Contributor
    Re: Object Selection based on type/layer
    05-04-2010 06:09 PM in reply to: faugustom
    You can try to use Entlasel routine. After, use the previous selection to apply a command.
    :smileyhappy:
    Rogerio
