I have one get area script I have used for the last few years in 2008-2009 autocad. Now in 2013 all I get is ####. The script is suppose to get the area of a polyline and puts the number in a text field. I have searched online and found a few others that dont work in 2013 either. I am wondering is it a setting I need to change in my 2013, or if the scripts really are not compatible.
;; local defun ;; get center of closed object (defun getcenter (obj / acsp cen rgn) (setq acsp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) rgn (car (vlax-invoke acsp 'Addregion (list obj))) cen (vlax-get rgn 'Centroid) ) (vla-delete rgn) cen ) ;; main part ;; label [plines w]/area field in sq. meters (defun c:larea (/ acsp adoc axss cpt ins ss txt mtxtobj) (vl-load-com) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (or acsp (setq acsp (vla-get-modelspace adoc ) ) ) (if (setq ss (ssget (list (cons 0 "*POLYLINE,*CONTOUR")))) (progn (setq axss (vla-get-activeselectionset adoc)) ;; iterate through the active selection set collection (vlax-for obj axss ; get a curve center (setq cpt (trans (getcenter obj) 0 1)) (setq txt ; displayed in meters to 3 decimal place: ;;; (strcat "%<\\AcObjProp Object(%<\\_ObjId " ;;; (itoa (vlax-get obj 'ObjectID)) ;;; ">%).Area \\f \"%lu2%pr3%ps[, m2]%ct8[1e-006]\">%" ;;; ) ; displayed in engineering to 2 decimal place: (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vlax-get obj 'ObjectID)) ">%).Area \\f \"%pr2%lu2%ct4%qf1\">%");<--pr2 means 2 decimal places, change to your suit ; displayed in engineering to 2 decimal place with addition SQ. FT.: ;;; (strcat "%<\\AcObjProp Object(%<\\_ObjId " ;;; (itoa (vlax-get obj 'ObjectID)) ;;; ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%") ); add mtext object to model space (setq mtxtobj (vlax-invoke acsp 'AddMText cpt ;insertion point 0.0 ; mtext width, optional = 0 txt ;string (field value) )) ; change mtext height accordingly to current dimension style text height: (vlax-put mtxtobj 'Height (getvar "dimtxt")); change (getvar "dimtxt") on text height you need ; set justifying to middle center (vlax-put mtxtobj 'AttachmentPoint acAttachmentPointMiddleCenter) ) ) ) (vla-regen adoc acactiveviewport) (princ) ) (princ "\n Type LAF to label objects with area field") (princ)
Solved by pbejse. Go to Solution.
@dglenn9000 wrote:I have one get area script I have used for the last few years in 2008-2009 autocad. Now in 2013 all I get is ####. The script is suppose to get the area of a polyline and puts the number in a text field. I have searched online and found a few others that dont work in 2013 either. I am wondering is it a setting I need to change in my 2013, or if the scripts really are not compatible.
;; local defun ......... ; displayed in engineering to 2 decimal place: (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vlax-get obj 'ObjectID)) ">%).Area \\f \"%pr2%lu2%ct4%qf1\">%");<--pr2 means 2 decimal places,
change the blue text to
(if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE")) (vlax-invoke-method (vla-get-Utility adoc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) )
HTH
Thanks pbejse! I didn't get around to using it at the time but a year laterI just found myself in the same predicament and updated my old script to work.
