Visual LISP, AutoLISP and General Customization
No function definition error
3 REPLIES 3
CADmgrMike
1369 Views, 3 Replies
I have a LISP routine that when I try to run it, I get this error message:
error: no function definition: F:LD
It worked fine with LDT2005, but when I installed LDT2009, it doesn't work.
this is the routine:
(DEFUN C:DAT ()
(F:LD)(LOAD "R:/ACAD 2009/APPS/GRADE_LSP/DATUM.LSP")
(PRINC)
I don't know a lot about AutoLISP, but I can usually fix small issues.
Mike Porter
https://provostandpritchard.com/
3 REPLIES 3
in reply to: CADmgrMike
> message: error: no function definition: F:LD It worked fine with
> LDT2005, but when I installed LDT2009, it doesn't work. this is the
> routine: (DEFUN C:DAT () (F:LD)(LOAD "R:/ACAD
> 2009/APPS/GRADE_LSP/DATUM.LSP") (PRINC) ) I don't know a lot about
Why don't you believe what the computer says?
The first thing your C:DAT function does is call the F:LD function,
which is not a part of AutoCAD and is not defined in this code extract.
So find out where it is defined and make sure to load it before calling
C:DAT.
stevor
To find it you could first search via the windows Find program, for files '*.lsp' and string 'n f:ld' in all the directories that contain the Autocad and LDT material.
If the function is in a vlx file, the Find may also work.
If found, it must be loaded before you start your work.
And the loading should have been made automatic by the LDT installation.
S
CADmgrMike
I do belive what my computer says.... Most of the time. 🙂
I assumed it was calling F:LD, but I can't figure out where F:LD resides.
I do know that this lisp routine and a couple others were part of something to to with Softdesk.
Mike Porter
”Boost
