Nentselp problem
3 REPLIES 3
ari.mont
470 Views, 3 Replies
Nentselp problem
I am writing a routine whose code and test file is attached. The purpose of this routine is to draw line segments on the boundary of a set of blocks selected by the user.
I managed to work when the block is at 0 ° rotation. But I am not able to run when the block is different from 0 ° rotation. The outline is drawn off the block and in reverse orientation.
I guess I have to change something in the transformation matrix returned by the function Nentselp.
I appreciate any help!
Ari
3 REPLIES 3
ari.mont
in reply to: ari.mont
I revised the code. Now the outline is drawn on the block, but in reverse orientation, yet!
can anyone help me?
Ari
pbejse
Ari
I tried your code on a diffrent block, Is it suppose to work on any selected blocks? I honestly have not given a good look at your code. I'm  trying to understand what the routine is all  about first..
CADaSchtroumpf
You can try my code, if you want draw points result, remove semi-colon :
;(setvar "cmdecho" 0)(foreach n lst_box (foreach el n (command "_.point" "_none" el)))
I hope that can help you, transformation matrix is hard...
(defun l-coor2l-pt (lst flag / )
  (if lst
    (cons
      (list
        (car lst)
        (cadr lst)
        (if flag
          (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst))
      (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag)
(defun transpts (apt matrix / )
  (mapcar
    '(lambda (arg / )
        (apply '+ (mapcar '* (mapcar (eval (quote arg)) matrix) apt))
        (cadddr ((eval arg) matrix))
    '(car cadr caddr)
(defun v_matr (dpt alphax alphay alphaz echx echy echz / )
  (list
    (list
      (* echx (cos alphaz) (cos alphay))
      (- (sin alphaz))
      (sin alphay)
      (car dpt)
    (list
      (sin alphaz)
      (* echy (cos alphaz) (cos alphax))
      (- (sin alphax))
      (cadr dpt)
    (list
      (- (sin alphay))
      (sin alphax)
      (* echz (cos alphax) (cos alphay))
      (caddr dpt)
    (list 0.0 0.0 0.0 1.0)
(vl-load-com)
(defun c:get-ptdef-in-block ( / js dxf_def def_blk pt_or ename l_pr e_next lst n dxf_ent pt_ins scalex_ins scaley_ins
  scale_z_ins space_colomn space_raw rot_ins nb_column nb_raw transform lst_pt pt_ori lst_box lst_bbox inc lst_all)
  (princ "\nClick on the block to identify it: ")
  (while (not (setq js (ssget "_+.:e:s" '((0 . "INSERT"))))))
  (princ (strcat "\nChoose " (cdr (setq dxf_def (assoc 2 (entget (ssname js 0))))) " blocks for working"))
  (while (not (setq js (ssget (list (cons 0 "INSERT") dxf_def )))))
  (setq def_blk (tblsearch "BLOCK" (cdr dxf_def)) pt_or (cdr (assoc 10 def_blk)))
  (setq l_pr (list 'StartPoint 'EndPoint 'Center 'InsertionPoint 'Coordinates 'FitPoints))
  (setq e_next (cdr (assoc -2 def_blk)) lst '())
  (while e_next
    (setq ename (vlax-ename->vla-object e_next))
    (foreach n l_pr
      (if (vlax-property-available-p ename n)
        (setq lst
          (if (or (eq n 'Coordinates) (eq n 'FitPoints))
            (append
              (if (eq (vla-get-ObjectName ename) "AcDbPolyline")
                (l-coor2l-pt (vlax-get ename n) nil)
                (if (and (eq n 'FitPoints) (zerop (vlax-get ename 'FitTolerance)))
                  (l-coor2l-pt (vlax-get ename 'ControlPoints) T)
                  (l-coor2l-pt (vlax-get ename n) T)
              lst
            (cons (vlax-get ename n) lst)
    (setq e_next (entnext e_next))
  (cond
    (lst
      (repeat (setq n (sslength js))
        (setq
          dxf_ent (entget (ssname js (setq n (1- n))))
          pt_ins (trans (cdr (assoc 10 dxf_ent)) 0 1)
          Scalex_ins (cdr (assoc 41 dxf_ent))
          Scaley_ins (cdr (assoc 42 dxf_ent))
          Scalez_ins (cdr (assoc 43 dxf_ent))
          space_column (cdr (assoc 44 dxf_ent))
          space_raw (cdr (assoc 45 dxf_ent))
          rot_ins (- (cdr (assoc 50 dxf_ent)) (atan (/ (cadr (getvar "UCSXDIR")) (car(getvar "UCSXDIR")))))
          nb_column (cdr (assoc 70 dxf_ent))
          nb_raw (cdr (assoc 71 dxf_ent))
          transform (v_matr '(0 0 0) 0.0 0.0 0.0 Scalex_ins Scaley_ins Scalez_ins)
          lst_pt (mapcar '(lambda (x ) (transpts x transform)) lst)
          transform (v_matr '(0 0 0) 0.0 0.0 (- rot_ins) 1.0 1.0 1.0)
          pt_ori (transpts pt_or transform)
          lst_pt (mapcar '(lambda (x ) (transpts x transform)) lst_pt)
          transform (v_matr (mapcar '- pt_ins (mapcar '* pt_ori (list scalex_ins scaley_ins scalez_ins))) 0.0 0.0 0.0 1.0 1.0 1.0)
          lst_box (cons lst_pt lst_box)
        (cond
          ((and (not (zerop nb_column)) (not (zerop nb_raw)))
            (repeat (1- nb_column)
              (setq lst_box (cons (mapcar '(lambda (x) (polar x rot_ins space_column)) (car lst_box)) lst_box))
            (setq lst_bbox lst_box inc 1)
            (foreach n lst_bbox
              (repeat (1- nb_raw)
                (setq lst_box (cons (mapcar '(lambda (x) (polar x (+ (* 0.5 pi) rot_ins) (* inc space_raw))) n) lst_box) inc (1+ inc))
              (setq inc 1)
        (setq lst_all (append lst_box lst_all) lst_box nil)
  lst_all
”Boost
