Visual LISP, AutoLISP and General Customization
Valued Contributor
Message 1 of 5 (124 Views)
Accepted Solution
Need help loading a particular net assembly
124 Views, 4 Replies
01-23-2013 07:27 AM
Hello everybody,
I need a little bit of help because I don't know how to program in lisp. I have a master lisp routine that runs when Autocad is opening. I have some computers running Autocad 2010 and others with Autocad 2012 and from the master lisp routine (which is the same) I need to load a net assembly (one for Autocad 2010 or another for Autocad 2012).
I was thinking to query for Autocad version and if it is Autocad 2010, then load the first dll, or if it is Autocad 2012 then load the second dll, but I don't know how to do this in lisp.
Thank you very much for your help.
e.g.
*Expert Elite*
Message 2 of 5 (117 Views)
Re: Need help loading a particular net assembly
01-23-2013 07:38 AM in reply to: e.g.
(if (Equal (getvar "ACADVER") "18.s (LMS Tech)" );AC2012
  (load "Ac2012xxxxx.dll")
    ); if not, do not do anything
(if (Equal (getvar "ACADVER") "18.0s (LMS Tech)" );AC2010
  (load "Ac2010xxxxx.dll")
Hope that helps
Henrique
Valued Contributor
Message 3 of 5 (110 Views)
01-23-2013 07:52 AM in reply to: hmsilva
Yes, thank you very much.
e.g.
*Expert Elite*
Message 4 of 5 (108 Views)
01-23-2013 07:53 AM in reply to: e.g.
You're welcome, e. g.
EDITED
e. g. wrote:
...I need to load a net assembly..
Sorry, I have read too fast!!!
(if (and (Equal (getvar "ACADVER") "18.s (LMS Tech)") ;AC2012
	 (findfile "Ac2012xxxxx.dll")
  (vl-cmdf "netload" "Ac2012xxxxx.dll")
(if (and (Equal (getvar "ACADVER") "18.0s (LMS Tech)") ;AC2010
  (vl-cmdf "netload" "Ac2010xxxxx.dll")
Henrique
*Expert Elite*
Message 5 of 5 (94 Views)
01-23-2013 08:47 AM in reply to: e.g.
and a typo
where is "18.s (LMS Tech)"  should be "18.2s (LMS Tech)" for AC2012
Henrique
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
