Hello everybody,
I need a little bit of help because I don't know how to program in lisp. I have a master lisp routine that runs when Autocad is opening. I have some computers running Autocad 2010 and others with Autocad 2012 and from the master lisp routine (which is the same) I need to load a net assembly (one for Autocad 2010 or another for Autocad 2012).
I was thinking to query for Autocad version and if it is Autocad 2010, then load the first dll, or if it is Autocad 2012 then load the second dll, but I don't know how to do this in lisp.
Thank you very much for your help.
e.g.
Solved by hmsilva. Go to Solution.
(if (Equal (getvar "ACADVER") "18.s (LMS Tech)" );AC2012 (load "Ac2012xxxxx.dll") ); if not, do not do anything (if (Equal (getvar "ACADVER") "18.0s (LMS Tech)" );AC2010 (load "Ac2010xxxxx.dll") ); if not, do not do anything
Hope that helps
Henrique
You're welcome, e. g.
EDITED
e. g. wrote:
...I need to load a net assembly..
Sorry, I have read too fast!!!
(if (and (Equal (getvar "ACADVER") "18.s (LMS Tech)") ;AC2012 (findfile "Ac2012xxxxx.dll") ) (vl-cmdf "netload" "Ac2012xxxxx.dll") ); if not, do not do anything (if (and (Equal (getvar "ACADVER") "18.0s (LMS Tech)") ;AC2010 (findfile "Ac2012xxxxx.dll") ) (vl-cmdf "netload" "Ac2010xxxxx.dll") ); if not, do not do anything
Henrique
