Set your ucs to object and select the text object. Make sure your ortho is on and draw your line or pline to the length desired.
Nice! Thanks.
Im sure that should be easy to write a lisp routine that would set the usc for while drawing the line and then set the ucs back to "previous" when the command is over.
Try:
; DXF data value from code number
(defun DXF_ (n aLst) (cdr (assoc n aLst)) )
; Text Line
(defun C:txl (/ dl en es ps pe p1 p2 tbx clns nlns dyr )
(setvar "cmdecho" 0) (terpri) (grtext -1 " AusCadd.com ")
(setq Clns (getvar "clayer") nlns "Text-Line")
(princ"\n Set Layer to: ") (prin1 lyns)
(if (not (equal (strcase (getvar "clayer")) (strcase nlns)))
(command "-layer" "make" nlns "") ) :
(if (and (setq es (ent_seld es "\n Sel Text Ent: "))
(setq en (car es) dl (entget en))
(= "TEXT" (DXF_ 0 DL)) )
(PROGN (redraw) ; expert >3
(command "UCS" "save" "temp" "ucs" "ob" en )
(princ " UCS saved to Temp, set to Object ")
(setq tbx (textbox dL) p1 (car tbx) p2 (cadr tbx)
dyr 3 ; can be entered each time, or upon file load, etc
ps (list (car p1) (- (/ tH dyr)) 0) ; left
pe (list (car p2) (- (/ tH dyr)) 0) ) ; right
(command "Line" "none" ps "none" pe "") ; "0" or 0 ?
(command "UCS" "res" "temp" ) ; restore UCS
(setvar "clayer" clns) ; Layer
) (princ" Nyet ") ) ; pr
(princ)
) ; def
@econnerly wrote:I have searched everywhere but have found nothing. There are a ton of lisp to match text rotation to a selected line, but not vice versa.
Anyone out there have anything?One thing comes to mind
POLAR TRACKING:
(defun c:test () (setvar 'polarmode 4) (setq Txt (car (entsel "\nSelect Text/Mtext: :"))) (wcmatch (cdr (assoc 0 (setq txt (entget txt)))) "*TEXT") (setvar 'polarang (cdr (assoc 50 txt))) (command "_line")) )
If you try mine, C:TXL, the lie:
needs to be replaced by:
(if (and (setq es (entsel "\n Sel Text Ent: "))
because Ent_SelD is a local subroutine to include a default selection, accidentally left in, and not appropriate for this. [sorry ]
Again, if you use c:TXL the following additions:
add the line
TH (dxf_ 40 dl)
after
because: unknown.
Also, Expert must be set to 4 or more, which it usally is, but a test and reset could have been added, yet was not.
@econnerly wrote:....
Or, you can change the SNAPANG System Variable to match the Text, rather than the UCS. If you want a single Line segment, in simplest terms:
(defun C:TAL (/ sang orth txt); = Text-Aligned Line
(setq
sang (getvar 'snapang)
orth (getvar 'orthomode)
txt (entget (car (entsel "\nSelect Text to Align Line with: ")))
); setq
(setvar 'snapang (cdr (assoc 50 txt)))
(setvar 'orthomode 1)
(command "_.line" pause pause "")
(setvar 'snapang sang)
(setvar 'orthomode orth)
If you want to be able to draw multiple sequential Line segments, or a Polyline:
(command "_.line"); or "_.pline"
(while (> (getvar 'cmdactive) 0) (command pause))
Either works with Mtext as well as Text. Add error handling, selected-object-type control, switching to Text's Layer, etc., as desired.
@stevor wrote:....
....(command "UCS" "res" "temp" ) ; restore UCS
You could avoid the need to save a temporary UCS [which you probably should also delete after you're done with it], by just using the Previous option to put it back where it was:
(command "UCS" "ob" en)
(command "UCS" "_previous") ; restore UCS
If you were doing multiple operations that might involve changing the UCS more than once in the process, then I could see more value in saving a temporary UCS to restore later.
Saving UCS as Temp, in reply to Kent, etal: Yep, and your "P" for Previous is the better way, for that case, and for most cases.
Save the UCS is a debug habit, not normally required.
Just account for the UCS being something other than world...
(defun c:Test (/ e d p) (vl-load-com) (setvar 'ERRNO 0) (if (and (progn (while (progn (setq e (car (entsel "\nSelect *Text object for angle: "))) (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again.")) ((eq (type e) 'ENAME) (if (not (wcmatch (cdr (assoc 0 (setq d (entget e)))) "MTEXT,TEXT")) (princ "\nInvalid object!") ) ) ) ) ) e ) (setq p (getpoint "\nSpecify first point: ")) ) (progn (vl-cmdf "_.line" "_non" p (strcat "<" (angtos (if (and (eq (cdr (assoc 0 d)) "TEXT") (zerop (getvar 'WORLDUCS))) (- (cdr (assoc 50 d)) (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 T) T)) ) (cdr (assoc 50 d)) ) (getvar 'AUNITS) 4 ) ) PAUSE ) (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) ) ) (princ) )
To Econnerly;
1. Notice the post of alanjt: I do not recall if my post included UCS translations.
2. And notice that you can change the Layer and LINE offset down distance, in the code.
And remove the temp UCS, as per Kent1's post.
I was actually thinking of another alternative that goes something like this:
(setq p1 (cdr (assoc 10 (setq b (entget (car (entsel)))))))
(command ".xline" p1 (polar p1 (cdr (assoc 50 b)) 1) "")
Yes, it's tested!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
