Multiple Xclip from one Xref
12 REPLIES 12
Message 1 of 13
kulfi
19772 Views, 12 Replies
Hi, Every one
is it possible to make multiple Xclip from same Xref.
Any help will be apperciated
Kulfi
Electronics Engineer
Pind Saudi Arabia
12 REPLIES 12
Message 2 of 13
in reply to: kulfi
Not as far is I know.
The trick we use is as follow.
Create a pline (or rectang) for each part you want to clip.
Now draw lines or rectangs that have very little spacing (1mm) between
the objects created before.
Trim it all off and make one big Pline of it, now use xclip-object.
Autocad wil now see the entire object as a clipping boundary.
regards,
Jan
kulfi wrote:
> Hi, Every one
> Thanks
Message 3 of 13
in reply to: kulfi
Yes.
Just attach it more than once.
Dave Alexander
wrote in message news:5416086@discussion.autodesk.com...
Hi, Every one
Message 4 of 13
kulfi
in reply to: kulfi
Mr. Jpdomein
ur trick is not clear anyhow if i clip one part of the drawing and make a block of that part bringing the master xref back again will it be possible.
Please give comments about this.
Kulfi
Pind Saudi Arabia
Message 5 of 13
kulfi
in reply to: kulfi
Hi, u are right but if the drawing is big there is chances that the computer may held.
i have posted an idea wt do u think about that.
Kulfi
Pind Saudi Arabia
Message 6 of 13
in reply to: kulfi
When you xclip the xrefs, it keeps the size of the drawing down so locking
up (?) should not be a problem.
Just remember to rename the xref before you attach it again.
Dave Alexander
wrote in message news:5420785@discussion.autodesk.com...
may held.
Message 7 of 13
in reply to: kulfi
DO NOT re-attach the xref, simply COPY it once it's in the drawing. That
way it's just like a copy of a block. If you re-attach it (renaming each
one) you will cause AutoCAD to reload EACH COPY of the xref every time you
regen. Simply copy the xref (to the same location) and xclip each one.
Hope this helps!
Andy
www.TheGoodPersonTest.net
"Dave Alexander" wrote in message
news:5422689@discussion.autodesk.com...
Dave Alexander
may held.
Message 8 of 13
in reply to: kulfi
The best way I have found that keeps the multiple clips in their
original spatial relationship to each other, is to copy the xref once
for each clip, run XCLIP for each clipped area, then make a block of the
clips. Not ideal, but you don't have to create super-thin connecting
bridges between the parts of the xref that you want to show.
kulfi wrote:
> Hi, Every one
> Thanks
Message 9 of 13
in reply to: kulfi
hi Bill, out of curiosity why do you make a block out of the multiple
XClips? I do a lot of multiple XClipping and have always just left them
as separate objects. I'm wondering if there is some advantage to
blocking them?
Dave
DDP
Message 10 of 13
kulfi
in reply to: kulfi
ya i have written a program which does this may some better idea can be there.
Check this and give me an idea how to improve this.
Kulfi
Pind Saudi Arabia
Message 11 of 13
riznasp
in reply to: kulfi
Hi Friends,
Does anyone have any update or any knowledge about how to do the multiple xclip with single xref?
Message 12 of 13
paullimapa
in reply to: riznasp
Hi riznasp
The other option is from the posting you already commented on:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Xclip-with-Multiple-Boundaries/m-p/28...
Paul Li
IT Specialist
@The Office
Message 13 of 13
in reply to: kulfi
1.Initial Xclip around the part of your xref you want to xclip.
2. copy the xref you just clipped and place it where you want.
3. click on the xref you just copied.
4. drag the pickboxes around the New area you want to clip.
5. Repeat the steps to clip other areas.
”Boost
