Hello to you
I am looking for how to change this seal that lisp account the selection blocks outgoing Autocad a table with the following columns result:
Column 1: Serial number, column 2: name of the block, column 3: number of identical blocks, column 4: block design.
sorting block name
change to achieve the following result:
Column 1: Serial number, column 2: attribute "BRAND" blocks various values "A" or "B" etc ... (the brand manufacturer several different brands), column 3 block name, column 4: attribute blocks "PRODUCT" different values "D" or "E" etc ... (the name of the product several different designation), column 5: number of identical blocks, column 6: block design.
sorting 1 of "BRAND" value with sort on 2 block name, with sort on 3 "PRODUCT" value.
This is a lisp that we use every day for tables nomenclature of blocks.
Thank you for your help in advance.
Very cordially.
Hervé
Hello you,
I have modify the lisp joint but i can't groupe with the "reference" tag at least. See the attached file TABM.lsp at modify and the Autocad 2013 file for the example.
Can you help me to resolve this thing.
Thanks for advance and best regards.
Hello to you,
I come to you because the lisp attached will not work with dynamic blocks. I get a list with names bizzares instead of the AutoCAD block name list. Can you throw them a look. In advance, thank you for your answer. cordially
