I'm having some issues trying to get the existing code to just select the text (only one per dwg) on layer "Floor_Label" rather than the entsel. Any tips would be very nice.
(defun c:m1 ( / e en entype pt)
; (setq txt1 (ssget "X" (list (cons 8 "Floor_Label"))))
(setq e (entsel) en (car e) entype (cdr (assoc 0 (entget en))))
(if (or
(= entype "HATCH")
(not (setq pt (cdr (assoc 10 (entget en)))))
(setq pt (nth 1 e))
(command "move" en "" pt)
Solved by pbejse. Go to Solution.
Try following for Text Entity or Replace "TEXT" with "MTEXT" if Multiline Text:
(setq txt1 (ssget "X" '((0 . "TEXT")(8 . "Floor_Label"))))
OR if you prefer
(setq txt1 (ssget "X" (list '(0 . "TEXT")(cons 8 "Floor_Label"))))
OR another option
(setq txt1 (ssget "X" (list (cons 0 "TEXT")(cons 8 "Floor_Label"))))
I like the first option, but there may be times when you need to use the other options if you are using variables to set the entity type or layer name.
@cummins600 wrote:I'm having some issues trying to get the existing code to just select the text (only one per dwg) on layer "Floor_Label" rather than the entsel. Any tips would be very nice.
You can cut it down to specifics by using a known values.
(ssget "_X" '((0 . "TEXT")(8 . "Floor_Label")(1 . "StringValue")));<--- known string value\Layer
(ssget "_X" '((0 . "TEXT")(8 . "Floor_Label")(40 . 2.50)(1 . "StringValue")));<--- known string valueLayer\Text Height
50 for rotaition 7 for textstyle and so on.....
HTH
Yes, those are good ones! Still trying to get rid of the (entsel) and replace with the known text selection so the user will not be prompted.
@cummins600 wrote:Yes, those are good ones! Still trying to get rid of the (entsel) and replace with the known text selection so the user will not be prompted.
Yes. thats exactly what those lines of codes do for you.
The "X in conjunction with ssget function will AUTOMATICALLY select the entity for you
Like
(defun c:m1 (/ e en entype pt)
(if (and (setq txt1 (ssget "X"
'((0 . "TEXT")
(8 . "Floor_Label")
(1 . "BEDROOM"))))
(= (sslength txt1) 1))
(command
"_.move"
txt1 ""
(cdr (assoc 10 (entget (ssname txt1 0))))
'(1.0 2.0 0.0))
it will select a TEXT entity with "Floor_label" layer and with a string value of "BEDROOM"
and if the selection set contains 1 object
Then it will move the entity from pt to this coordinates '(1.0 2.0 0.0))
No prompt for selection needed
Thanks a bunch! Got what I'm looking for now. Here's ver that worked for me.
(defun c:m1 (/ e en entype pt LRC)
(setq LRC (list (nth 0 (getvar "extmax")) (nth 1 (getvar "extmin"))))
'((0 . "MTEXT")
(8 . "Tri_triFloor_Label")
(command
"_.move"
txt1 ""
LRC)
;'(1.0 2.0 0.0))
@cummins600 wrote:Thanks a bunch! Got what I'm looking for now. Here's ver that worked for me.
You are welcome cummins600
Glad I could help
Cheers
