What specifically would you like to modify... typically the Object Properties
Manager dialog box pops up.
(DCPROPS is available if you have Express Tools, volume 7 or higher)
DBLCLKEDIT on, DCPROPS off, PICKFIRST 1 = OPM will open
when double clicking on entities except text, text editor
will open, cannot close OPM with ESCAPE or CTRL+Z
DBLCLKEDIT off, DCPROPS on, PICKFIRST 0 or 1 = OPM will open
when double clicking on entities including text, text editor
will not open, OPM will close with ESCAPE or CTRL+Z
DBLCLKEDIT on, DCPROPS on, PICKFIRST 1 = OPM will open
will also open, OPM will close with CTRL+Z
DBLCLKEDIT on, DCPROPS on, PICKFIRST 0 = OPM will open
(another nickel added to the till for Kent Elrod)
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Jake wrote:
> I don't have Express Tools, only plain AutoCAD or LDT. Now what?
> "STEVE-O" wrote in message
> news:EBD39B7936731384ED944F5599497B29@in.WebX.maYIadrTaRb...
> > if you have express menu, go to EXPRESS - TOOLS - DOUBLE CLICK PROPERTIES
> > "Jake" wrote in message
> > news:9E782D0D4564F8DA6BED65FA7198B887@in.WebX.maYIadrTaRb...
> > > How do I change / add to the defaults for doubleclick editing? For
> > example,
> > > what would I do to modify the double-click default for an arc?
> > > JL
