- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Mleader lisp - Help please!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
if anyone can or want to help, I need help removing the "Invalid Input" message. The routine works its just that message.
Israel Ramos
(defun c:KeyLeader ()
(setvar "CMDECHO" 0)
;(setvar "ATTDIA" 0)
;(setvar "ATTREQ" 0)
(setq |get:CLAYER| (getvar "CLAYER"))
(setq *error* *KeyNote_error*)
(command "_.LAYER" "M" "E-TEXT" "C" "7" "" "")
;-LAYER;M;E-TEXT;C;7;;;
(setq |TagNo| (getstring "\nSpecify Tag No. :"))
;;;;;;;;;(setq |pt1| (getpoint "\nSpecify point: "))
(setvar "NOMUTT" 1)
;;;;;;;;;(command "_.MLEADER" pause pause |TagNo|)
(command "_.MLEADER" |pt1|)
;;;;;;;;;(command "_.MLEADER")
;;;;;;(while (= (getvar "CMDACTIVE") 1) (command pause |TagNo|))
(while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (command pause |TagNo|))
(setvar "NOMUTT" 0)
(princ)
(setvar "CLAYER" |get:CLAYER|)
(setvar "CMDECHO" 1)
(princ)
(defun c:TableSearch->Block ()
(setq |BlockName| "SL_DimText")
(if (=(null(tblsearch "BLOCK" "HexKey"))T)
(progn
(command "_.INSERT" (strcat "C:\\Dropbox\\SL_Acad2012\\Templates\\" |BlockName| ".dwg") "0,0" ".01" ".01" "0")
(setq |Erase:Blk| (entlast))
(command "ERASE" |Erase:Blk| "")
;(command "_.PURGE" "B" |BlockName| "N")
(princ)
(defun c:HexArrow ()
(c:TableSearch->Block)
(setvar "CMLEADERSTYLE" "HexArrow")
(c:KeyLeader)
(princ)
(defun *KeyNote_error* (msg)
(princ)
(princ)
Re: Mleader lisp - Help please!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
(setvar "ATTREQ" 1)
(setvar "ATTDIA" 0)
Variable |pt1| not defined, you can use
(command "_.MLEADER" (getpoint) |TagNo|)
or prompt for |pt1|
|pt1| (getpoint "\nPick point"))
(command "_.MLEADER" |pt1| |TagNo|)
no need for this
Unless you are planning to loop the command
(while (setq |pt1| (getpoint "\nSpecify point: "))
(command "_.MLEADER" |pt1| |TagNo| pause)
(setq |TagNo| (itoa
(1+ (atoi |TagNo|)))))
HTH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you very much!
I really appreciate the help, please let me know if I can do anything to return the favor.
Israel Ramos
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
iramos.israel wrote:Thank you very much!
Israel Ramos
Glad i could help Israel If there's anything else you need dont hesitate to ask.
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is the final code for the Mleader lisp. Thanks to those who helped me get it together.
Israel Ramos
CAD/BIM Operator
(setvar 'CMLEADERSTYLE "HexArrow")
(c:Arrow_MLeader)
(princ)
(defun c:MchArrow ()
(setvar'CMLEADERSTYLE "MchArrow")
(c:Arrow_MLeader)
(princ)
(defun c:EqpArrow ()
(setvar 'CMLEADERSTYLE "EqpArrow")
(c:Arrow_MLeader)
(princ)
(defun c:TextArrow ()
(setvar 'CMLEADERSTYLE "TxtArrow")
(c:Arrow_MLeader)
(princ)
(defun c:HexTag ()
(setvar 'CMLEADERSTYLE "HexTag")
(c:Tag_MLeader)
(princ)
(defun c:MchTag ()
(setvar 'CMLEADERSTYLE "MchTag")
(c:Tag_MLeader)
(princ)
(defun c:EqpTag ()
(setvar 'CMLEADERSTYLE "EqpTag")
(c:Tag_MLeader)
(princ)
(defun c:HexLoop ()
(setq |PFX| "Hex")
(c:Loop_MLeader)
(princ)
(defun c:MchLoop ()
(setq |PFX| "Mch")
(c:Loop_MLeader)
(princ)
(defun c:EqpLoop ()
(setq |PFX| "Eqp")
(c:Loop_MLeader)
(princ)
(defun c:TextLoop ()
(setq |PFX| "Txt")
(c:Loop_MLeader)
(princ)
(defun c:Tag_MLeader ()
(setvar 'CMDECHO 0)
(setvar 'ATTREQ 1)
(setvar 'ATTDIA 0)
(setq |clayer| (getvar 'CLAYER))
(setq |orthomode| (getvar 'ORTHOMODE))
(setvar 'ORTHOMODE 1)
(command "_.LAYER" "M" "E-KEYNOTE" "C" "7" "" "LW" "0.35" "" "")
(while |TagNo|
(command "_.MLEADER" "H" pause |TagNo|)
(princ)
(defun c:Arrow_MLeader ()
(setvar 'CMDECHO 0)
(setvar 'ATTREQ 1)
(setvar 'ATTDIA 0)
(while
(command "_.MLEADER" "H" |pt1| (progn (initget 32)(getpoint |pt1|)) pause |TagNo|)
(princ)
(defun c:Loop_MLeader ()
(setvar 'CMDECHO 0)
(setvar 'ATTREQ 1)
(setvar 'ATTDIA 0)
(setq |TagNo| (getstring "\nSpecify Text. :"))
(while
(setq |pt1| (getpoint "\nSpecify Start Point: "))
(initget 32)
(setq |pt2| (getpoint |pt1| "\nSpecify Next Point: "))
(command "_.LINE" |pt1| |pt2| "")
(setq |Line| (entlast))
(initget 32)
(setq |pt3| (getpoint |pt2| "\nSpecify Loop Direction: "))
(command "_.ERASE" |Line| "")
(setq |Angle| (*(angle |pt1| |pt3|) (/ 180 pi)))
(progn
(setq |X1| (car |pt1|))
(setq |Y1| (cadr |pt1|))
(setq |X2| (car |pt2|))
(setq |Y2| (cadr |pt2|))
(setq |pt3| (list |X1| |Y2|))
(cond
((and(> |Angle| 0)(<= |Angle| 90)) (setq |SFX| "Loop2"))
((and(> |Angle| 90)(<= |Angle| 180)) (setq |SFX| "Loop1"))
((and(> |Angle| 180)(<= |Angle| 270)) (setq |SFX| "Loop2"))
((and(>= |Angle| 270)(< |Angle| 360)) (setq |SFX| "Loop1"))
(setvar 'CMLEADERSTYLE (strcat |PFX| |SFX|))
(command "_.MLEADER" "H" |pt1| |pt2| pause |TagNo|)
(princ)
(setvar 'CMDECHO 0)
(progn
(command "_.INSERT" (strcat "X:\\SL_Acad2013\\cuix\\05-Symbols\\" |BlockName| ".dwg") "0,0" ".01" ".01" "0")
(if (=(null(tblsearch "BLOCK" "EqpKey"))T)
(progn
(if (=(null(tblsearch "BLOCK" "MchKey1"))T)
(progn
(princ)
(setq |TagType| nil)
(setq |TagNo| nil)
(setvar 'CLAYER |clayer|)
(setvar 'ORTHOMODE |orthomode|)
(setvar 'NOMUTT 0)
(setvar 'ATTREQ 1)
(setvar 'ATTDIA 1)
(setvar 'CMDECHO 1)
(princ)
(princ)
