Hello everyone,
I am using autocad 2013 and importing PDFs into the drawing and recently the OSnap points within the pdf are mssing. The PDFs are of floorplans and I was able to measure from wall to wall using endpoints and midpoints. Now I am only able to select the endpoints on the frame of the pdf.
Is there a switch that might have been turned off?
Thanks.
Hello
If your PDF shows an raster image, you will not be able to snap on vector lines ...
This PDF has been plotted/printed with which software on which PDF Driver ?
Bye, Pat
Patrice BRAUD
So, if it's the way the dwg was plotted to pdf, that will explains everything. I'll have to verify their method and have them change it.
Thanks for your input.
