Can i know that from which lisp file is this message coming please so that i can remove this message also tell me if i remove base.dcl file from the directory what effect AutoCAD.
; error: bad argument type: stringp nil
AutoCAD menu utilities loaded.; error: LOAD failed: "acadappp.lsp"
K,
It's very difficult to find the cause of the error without seeing the code. However, it appears that somewhere you are using a string with a nil value. See the couple of examples below to get you started:
(setq filename nil)
(strcat (getvar "DWGPREFIX") filename)
nil
(setq filename (getvar "DWGNAME"))
"Drawing1.dwg"
"C:\\Users\\scottb\\Documents\\Drawing1.dwg"
Regarding base.dcl I'll let somebody else answer that, although I'm sure they'll ask "why?"
S
Thanks but this is not what i am asking i am asking from which file this message is coming up.
thanks
Hmmm. I'd really need to know what files you're loading and what their contents are before I can tell you what the problem is. Surely you must know that.
Ok if u want to know the exact problem than i will like to tell u that there is file acadppp.lsp which exist in the acad path and i know that this is not acad application file tell me who to remove this file because if i remove it comes back again.
thanks
base.dcl is AutoCAD's definition file for it's core dialog boxes as well as defining some basic element groups.
Deleting or renaming this file will have serious consequences to the behavior of those windows that have the "OK". "OK/CANCEL", and/or the "OK/CANCEL/HELP" buttons along the bottom...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
There is a virus for cad files that creates this acadappp.lsp and also some acad.lsp you can identify them by the size 110kb
delete in all your computers and networks files with those characteristics to solve your problem
avast antivirus detects it but panda and others does not
Pedro
I have deleted all file acadappp.p but i have dew questions
1. how it is crerated
2. what is the cause of this
3. what is the best solution of removing so that it does not come back.
thanks
