Hey guys,
I have a simple question as I know what I am looking for but can't figure out how to do it...
I have created a new menu in my .cui and can't seem to get it to load on my screen. I know there is a way to turn on/off ,at each work station, which menu's load and/or don't load by simply checking a box. How do I get to this screen?
Solved by paullimapa. Go to Solution.
WSSETTINGS command will control what is displayed
CUI command will let you customize
CUILOAD command will let you load more menus
CUIUNLOAD command will let you unload menus
My cui is already loaded. I am looking to try and check the box to turn on a drop down menu that I have created. Just wondering how to get to that screen while in the Custom User Interface dialogue area...
When inside the CUI, make sure on top of the left pane All Customization Files is selected
Then select on the left window under Worspaces the one you want to include the partial menu
Next on top of the right pane select Customize Workspace button
Now you scroll down the window on the left to see check boxes on all menus that are already included
Find the one you've added that is not checked and check it.
That partial menu will now show up on the right pane.
Click the Done button on top of the right pane when finished.
