Personally, I would stay away from modifying or editing AutoCADs menus, and
just create custom partial menus. Have a reactor or some lisp utility to
check for that menu being loaded.
My 2 cents.
Rudy@Cadentity.com
AUTODESK
Authorized Developer
www.Cadentity.com
MASi
"BillZ" wrote in message
news:26154407.1071768704297.JavaMail.jive@jiveforum2.autodesk.com...
> R2004:
> In my Acad.mnl file I have a line to check for a custom .mns file and if
the file is found, I use the menuload command to load it using autolisp.
> When I make changes to my .mns and delete the old .mnc and .mnr and start
autocad, I can see when autocad starts that it is recompiling an .mnc
and.mnr, but the changes to the .mns are not evident. I put some (princ
"**Hello**") in my .mnl file, but I don't see the prompt on the sceen. It's
seems as if my acad.mnl is being ignored.
> This is the code I put in my acad.mnl:
> (if (setq mnuloc (findfile (strcat "G:/autolisp/autocad_2004_support/"
(getvar "loginname") "_acad.mns")))
> (progn
> (princ mnuloc)
> (command ".menuunload" "acad")
> (command ".menuload" mnuloc)
> (princ (strcat "\nG:/autolisp/autocad_2004_support/" (getvar
\"loginname\") "_acad.mns Loaded."))
> My support paths are correct and there are no other matching files in any
of the support paths.
> If I manually load the .mns file after autocad is up, then I see the
changes. Why?
> Bill
