I have loaded our Civil cui file into AutoCAD with a lisp file calling CUILOAD.
The ribbon shows, but the menu does not, however, when I go into the CUI File and examine it, my workspace shows that the Civil menu should be showing (see attached image). Is there a way around this?
Open the CUI and expand Workspaces in the upper-left pane.
Highlight the desired Workspace, right-click and select "Current".
Now that it is current, and still highlighted, look in the lower-right pane and tailor your display to your liking.
Next, see the "Customize Workspace" button? Select that.
The display will flicker, and now boxes with and without green checkmarks inside are showing.
In the upper-left pane, expand tree and check or uncheck to your liking.
In the upper-right pane, expand and arrange the order to your liking (drag & drop).
Select the "Apply" button.
Select the "Done" button.
Right-click the desired Workspace and select "Current" again (this is an iffy item on some versions).
Select the "OK" button.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
HI....
step1) convert CUI to MNU
step2) compile menu file (*.mnu) to LISP generator with the programne "COMNULSP.exe"
result on idsk topoxcad.lsp"
step3)you run the autocad.exe or acad.exe
step4)you load "topoxcad.lsp" inacad.exe
step5)you enter at line command "C:Q2" or (defun C:Q2"
i hope, my solution work fine ... you send to me, the private message........
