Make lines orthogonal
4 REPLIES 4
spantazis
1858 Views, 4 Replies
Hi All,
I have scoured this site and found some lisp routines that come close but aren't exactly what I need. I have a file with a number of building footprints. They are not orthogonal to the view or each other but don't need to be. I would, however, like the lines that make up a closed shape, closed poly or otherwise, to be perpendicular to each other. All of the lisp routines I have found make each line orthogonal to the view and they lose their endpoint connection-not good. This one seems to come close but I can't get it to work:
;;Begin Lisp...
; orthoize.lsp
; d. philip
; 98.06.22
; function to straighten selected line entities within given angle range.
; as written, this func will keep the line's midpoint in the same spot approx.
(defun c:orthoize ( / svcmde -_rang -_ss-x -_ss-u -_slen -_indx
                      -_entn -_enty -_pnt1 -_pnt2 -_ang1 -_dist
                      -_mid1 -_ang2 -_pnta -_pntb )
  (setq svcmde (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (initget 1)
  (setq -_rang (getangle "\nEnter tolerance angle: "))
  (setq -_ss-x (ssget "X" (list (cons 0 "LINE"))))
  (prompt "\nSelect lines to straighten: ")
  (setq -_ss-u (ssget))
  (setq -_slen (sslength -_ss-u)
        -_indx 0
  (repeat -_slen
    (setq -_entn (ssname -_ss-u -_indx)
          -_enty (entget -_entn)
          -_indx (1+ -_indx)
    (if (ssmemb -_entn -_ss-x)       ; if entity is a line [member of
-_ss-x]...
      (progn                         ; then get endpoints.
        (setq -_pnt1 (cdr (assoc 10 -_enty))
              -_pnt2 (cdr (assoc 11 -_enty))
              -_ang1 (angle -_pnt1 -_pnt2)
              -_dist (/ (distance -_pnt1 -_pnt2) 2.0)
              -_mid1 (polar -_pnt1 -_ang1 -_dist)
        (cond
          ((equal -_ang1 0.0 -_rang)       (setq -_ang2 0.0))        ;
angle above 0 degrees
          ((equal -_ang1 (* pi 0.5) -_rang)(setq -_ang2 (* pi 0.5))) ;
angle around 90 degrees
          ((equal -_ang1 pi -_rang)        (setq -_ang2 pi))         ;
angle around 180 degrees
          ((equal -_ang1 (* pi 1.5) -_rang)(setq -_ang2 (* pi 1.5))) ;
angle around 270 degrees
          ((< (- (* pi 2.0) -_ang1) -_rang)(setq -_ang2 0.0))        ;
angle below 0 (360) degrees.
          (T (setq -_ang2 nil))
        (if -_ang2
          (progn
            (setq -_pnta (polar -_mid1 (+ -_ang2 pi) -_dist)
                  -_pntb (polar -_mid1 -_ang2 -_dist)
            (setq -_enty (subst (cons 10 -_pnta) (assoc 10 -_enty)
-_enty)
                  -_enty (subst (cons 11 -_pntb) (assoc 11 -_enty)
-_enty)
            (entmod -_enty)
          )  ; end of progn.
        )  ; end of if.
      )  ; end of progn.
    )  ; end of if.
  )  ; End of repeat.
  (setvar "CMDECHO" svcmde)
  (setq -_ss-u nil  -_ss-x nil)
  (princ)
;princ "\nLine straighten function is now loaded.  Enter  orthoize  to
run."
princ
;========================== End of file =========================
Tags (1)
4 REPLIES 4
Patchy
in reply to: spantazis
2012 has it. It's called Parametric, Perpendicular.
spantazis
in reply to: Patchy
I wanted to make sure I wasn't completely ignorant so I typed in both Parametric and Perpendicular in the Command line and nothing happened. Then I searched the words in AutoCAD Help and nothing came up. Could you elaborate?
Patchy
Make lines to be perpendicular to each other ?
See the attachment
spantazis
in reply to: Patchy
Well shut my mouth. That'll do it. Thank you very much.
”Boost
