Hi All,
I have scoured this site and found some lisp routines that come close but aren't exactly what I need. I have a file with a number of building footprints. They are not orthogonal to the view or each other but don't need to be. I would, however, like the lines that make up a closed shape, closed poly or otherwise, to be perpendicular to each other. All of the lisp routines I have found make each line orthogonal to the view and they lose their endpoint connection-not good. This one seems to come close but I can't get it to work:
;;Begin Lisp...
; orthoize.lsp
; d. philip
; 98.06.22
; function to straighten selected line entities within given angle range.
; as written, this func will keep the line's midpoint in the same spot approx.
(defun c:orthoize ( / svcmde -_rang -_ss-x -_ss-u -_slen -_indx
-_entn -_enty -_pnt1 -_pnt2 -_ang1 -_dist
-_mid1 -_ang2 -_pnta -_pntb )
(setq svcmde (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(initget 1)
(setq -_rang (getangle "\nEnter tolerance angle: "))
(setq -_ss-x (ssget "X" (list (cons 0 "LINE"))))
(prompt "\nSelect lines to straighten: ")
(setq -_ss-u (ssget))
(setq -_slen (sslength -_ss-u)
-_indx 0
(repeat -_slen
(setq -_entn (ssname -_ss-u -_indx)
-_enty (entget -_entn)
-_indx (1+ -_indx)
(if (ssmemb -_entn -_ss-x) ; if entity is a line [member of
-_ss-x]...
(progn ; then get endpoints.
(setq -_pnt1 (cdr (assoc 10 -_enty))
-_pnt2 (cdr (assoc 11 -_enty))
-_ang1 (angle -_pnt1 -_pnt2)
-_dist (/ (distance -_pnt1 -_pnt2) 2.0)
-_mid1 (polar -_pnt1 -_ang1 -_dist)
(cond
((equal -_ang1 0.0 -_rang) (setq -_ang2 0.0)) ;
angle above 0 degrees
((equal -_ang1 (* pi 0.5) -_rang)(setq -_ang2 (* pi 0.5))) ;
angle around 90 degrees
((equal -_ang1 pi -_rang) (setq -_ang2 pi)) ;
angle around 180 degrees
((equal -_ang1 (* pi 1.5) -_rang)(setq -_ang2 (* pi 1.5))) ;
angle around 270 degrees
((< (- (* pi 2.0) -_ang1) -_rang)(setq -_ang2 0.0)) ;
angle below 0 (360) degrees.
(T (setq -_ang2 nil))
(if -_ang2
(progn
(setq -_pnta (polar -_mid1 (+ -_ang2 pi) -_dist)
-_pntb (polar -_mid1 -_ang2 -_dist)
(setq -_enty (subst (cons 10 -_pnta) (assoc 10 -_enty)
-_enty)
-_enty (subst (cons 11 -_pntb) (assoc 11 -_enty)
-_enty)
(entmod -_enty)
) ; end of progn.
) ; end of if.
) ; end of progn.
) ; end of if.
) ; End of repeat.
(setvar "CMDECHO" svcmde)
(setq -_ss-u nil -_ss-x nil)
(princ)
;princ "\nLine straighten function is now loaded. Enter orthoize to
run."
princ
;========================== End of file =========================
I wanted to make sure I wasn't completely ignorant so I typed in both Parametric and Perpendicular in the Command line and nothing happened. Then I searched the words in AutoCAD Help and nothing came up. Could you elaborate?
