I have tools like flatten and toolpac to correct plines and other things to be parallel to the ucs (world), but not for dimensions.
I attached a file with problem dins, does anyone have a tool to get them back to flat?
thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
This will project linear dimension on XY plan (of WCS)
(defun C:TEST (/ ss i e old new n)
(if
(setq ss (ssget '((0 . "DIMENSION"))))
(repeat (setq i (sslength ss))
(setq e (entget (ssname ss (setq i (1- i))))
n (cdr (assoc 210 e))
(if
(member '(100 . "AcDbAlignedDimension") e)
(progn
(setq old (assoc 11 e)
new (trans (cdr old) n 0)
new (list 11 (car new) (cadr new) 0.0)
e (subst new old e)
(foreach p '(10 13 14)
(setq old (assoc p e)
new (reverse (cons 0.0 (cdr (reverse old))))
e (subst new old e)
(setq e (subst '(12 0.0 0.0 0.0) (assoc 12 e) e)
e (subst '(210 0.0 0.0 1.0) (assoc 210 e) e)
(entmod e)
(princ)
It works on your sample, but, since is a projection, in some other situations, it might lead to undesired results.
For example, if a dimension is aligned to a cube main diagonal, after projection it will measure a diagonal of the base.
In fact, even for your sample the measurements are a bit altered, since it measure 3d points and the normal vector of all your dimensions are different than WCS. So use it on a copy and check if it is OK.
EDIT: code changed.
