I would like to make a block with Entmake.
This works fine with me, but how do I give my block the properties AlowExplode, Annotative, ScaleUniformly and InsUnits ?
w.k.r.
JC
These are stored in the BLOCK_RECORD Entity, to my knowledge, you will need to entmake the BLOCK entity, its contents, then the ENDBLK entity, then modify the corresponding BLOCK_RECORD entity.
Here is an example of setting the InsUnits for a block created using entmake.
This works fine with InsUnits (dxf 70) AllowExplode (dxf 280) and ScaleUniformly (dxf 281).
Does anyone know how to make an existing block annotative with lisp ?
w.k.r.
JC
Extension Dictionaries. That's pretty much all I know and I don't understand how they work enough to typically mess with them. But that's what an annotative block has that regular ones don't.
