• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Active Contributor
    Make Block
    99 Views, 3 Replies
    11-08-2011 07:13 AM
    I would like to make a block with Entmake.
    This works fine with me, but how do I give my block the properties AlowExplode, Annotative, ScaleUniformly and InsUnits ?
    w.k.r.
    JC
    Please use plain text.
    Valued Mentor
    Re: Make Block
    11-08-2011 07:21 AM in reply to: jcartigny
    These are stored in the BLOCK_RECORD Entity, to my knowledge, you will need to entmake the BLOCK entity, its contents, then the ENDBLK entity, then modify the corresponding BLOCK_RECORD entity.
    Here is an example of setting the InsUnits for a block created using entmake.
    Lee Mac Programming
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
    Just another Swamper
    Active Contributor
    Re: Make Block
    11-08-2011 08:47 AM in reply to: jcartigny
    This works fine with InsUnits (dxf 70) AllowExplode (dxf 280) and ScaleUniformly (dxf 281).
    Does anyone know how to make an existing block annotative with lisp ?
    w.k.r.
    JC
    Valued Mentor
    Re: Make Block
    11-08-2011 12:41 PM in reply to: jcartigny
    Extension Dictionaries.  That's pretty much all I know and I don't understand how they work enough to typically mess with them.  But that's what an annotative block has that regular ones don't.
    ---sig---------------------------------------
    '(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
