need to add dxf group of 75 '(75 . 0)
(defun C:TEST () (and (setq mtext (car(entsel "\nSelect Mtext to change columns type: "))) (setq lst (entget mtext)) (= (cdr(assoc 0 lst)) "MTEXT") (setq lst (if (assoc 75 lst) (subst (cons 75 0) (assoc 75 0) lst) (append lst (list(cons 75 0))) ) ) (entmod lst) ) (princ) )
Adding the DXF code changes the column type. I cannot select the mtext globally. Is DXF code 75 some sort of XDATA?
