Visual LISP, AutoLISP and General Customization
Loop file names in command prompt
5 REPLIES 5
The_Caddie
776 Views, 5 Replies
I’m not so good with loops so I was wondering if anyone could help.
I have a parent directory with x-amount of folders contained inside. I say X-amount because I would like to keep adding or deleting folders as time progresses. I want the folders contained within this parent directory do be read into a lisp variable and then be printed to the command prompt till every folder is displayed by name, then the loop may stop.
Could somebody help with this?
5 REPLIES 5
phanaem
in reply to: The_Caddie
Try this
;prompt directory structure
;usage:
;  - dir = a directory to search
;  - flg = a flag. If True, look in subdirectories
; (prompt_dir "D:\\Temp" nil)
; (prompt_dir "D:\\Temp" T)
; Stefan M. 06.12.12 (defun prompt_dir (dir flg) (foreach sub (vl-remove "." (vl-remove ".." (vl-directory-files dir nil -1))) (princ (strcat "\n" dir "\\" sub)) (if flg (prompt_dir (strcat dir "\\" sub) flg)) ) (princ) )
The_Caddie
in reply to: phanaem
oo
EEH?
hmsilva
The_Caddie wrote:
...I want the folders contained within this parent directory do be read into a lisp variable
and then be printed to the command prompt till every folder is displayed by name, then the loop may stop...
if I understood correctly try:
; Peter Tobey
(defun get-subdirs ( path )
(vl-load-com)
(apply (quote append)
(cons (list path)
(mapcar '(lambda (x) (get-subdirs (strcat path x "\\")))
(cddr (vl-directory-files path nil -1)))))
; test
(defun c:test(/ dir dir_lst)
(setq dir "C:\\test\\test\\"); your dir path
(if (setq dir_lst (get-subdirs dir))
   (foreach n dir_lst (prompt (strcat "\n" n "\n")))
Hope that helps,
Henrique
pbejse
@phanaem wrote:
Try this....
I was planning to write a similar recursion code using "Scripting.FileSystemObject" but its not near as fast as the one you posted.
Good show phanaem 🙂
phanaem
in reply to: pbejse
Good show phanaem 🙂
Very kind of you, pBe.Thanks a lot.
I'm still waiting The_Caddie to tell me if and what is wrong with my lisp...
”Boost
