I would like to swap the attribute value with a preset value
Example
attribute value NAME
replace with BROWN
I know that the find command would work for this, but I'm trying to save time by not entering that info all the time.
@tsbrown wrote:I would like to swap the attribute value with a preset value
Example
replace with BROWN
Are you refering to an exact string value match?
It wil be faster search if you are targeting a specific block name/Attribute tag otherwise a code will search the entire drawing database to find the target.
Have time to kill
Specific Block name/TAG/String to replace
(defun repn (bn tg os ns / ss i e ) (if (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1) (cons 2 (strcat bn ",`*U*"))))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (cond ((and (Eq (strcase (vla-get-effectivename e)) (strcase bn)) (foreach itm (vlax-invoke e 'GetAttributes) (if (and (eq (vla-get-tagstring itm) (strcase tg)) (eq (strcase (vla-get-textstring itm)) (strcase os))) (vla-put-textstring itm ns)))))) ) )(princ) )
(repn "Blockname" "TAG" "NAME" "BROWN")
(repn "Blockname" <----- Block name
"TAG" <-------------- Attribute TAG
"NAME" <------------ String to replace
"BROWN" <------- New string
OR for multiple block names and TAG
(defun repnL (bnl tgL os ns / ss i e ) (if (and (listp bnl)(listp tgl) (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1) (cons 2 (apply 'strcat (cons "`*U*," (mapcar '(lambda (k) (strcat k ",")) bnl)))))))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (cond ((and (member (strcase (vla-get-effectivename e)) (mapcar 'strcase bnl)) (foreach itm (vlax-invoke e 'GetAttributes) (if (and (member (vla-get-tagstring itm) (mapcar 'strcase tgl)) (eq (strcase (vla-get-textstring itm)) (strcase os))) (vla-put-textstring itm ns)))))) ) )(princ) )
(repnL '("Blockname1" "Blockname2") '("TAG" "OTHERTAG") "NAME" "BROWN")
(repnL '("Blockname1" "Blockname2") <----- block name list
'("TAG" "OTHERTAG") <-------------- Attribute TAG
And Brute Force method, regardless of blockname and attribute TAG. case senstive input for string to find
(defun c:repnbf (/ ns os ss i e ) (if (and (setq os (getstring T "\nEnter attribute string to replace: "))(not (eq os "")) (setq Ns (getstring "\nEnter new string: "))(not (eq ns "")) (setq ss (ssget "_X" '((0 . "INSERT")(66 . 1)))) ) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (foreach itm (vlax-invoke e 'GetAttributes) (if (eq (strcase (vla-get-textstring itm)) os) (vla-put-textstring itm ns))) ) )(princ) )
Command: REPNBF
Enter attribute string to replace: NAME
Enter new string: BROWN
HTH
Thanks for the help
I copy and loaded the first command and I get a error:
Command: _appload BROWN.lsp successfully loaded.
Command: too many arguments
Command:
I have attach the lisp file
I'm running 2012 if that makes a difference.
@tsbrown wrote:Thanks for the help
Command:
tsbrown,
Do not save the code as i had posted it. I'll save a copy for you and attach it here. but first i need to ask you a couple of questions:
What is the name of the block that shows the NAME string?
What is the TAG string of that particular attribute?
Of the three snippets i posted, the first and second one requires an argument for Block name/Tag name / string to replace/ new string
If you are not sure as to what im refering to. use the 3rd code, that will ask you for "what is" and "what will", but the whole point of your posts is saving time by not typing the info.
We can include the info on the 3rd code [hard-coded] , or use the 1st or 2nd code and supply the info on the sub-function and it will run upon loading.
Hence i need the info from you or you can type it yourself if its a confidentiality issue 🙂
the last line of the "saved" brown.lsp file should be in this format
(brown "Blockname" "TAG" "NAME" "BROWN")
Granting the info are correct. or like i've said, hard-coded onto the routine. You can post an example of the block, sans "confidential" info. or provide me the block name and/or TAG
What say you tsbrown?
Here's another option:
Batch find and replace by Lee Mac or Batch Attribute Editor by Lee Mac
Download the file and save. You may need to type in the info, YES, but one time only. the programs on those link will processed multiple drawing in one go.
HTH
What is the name of the block that shows the NAME string? AVI_TB_INFO_B
What is the TAG string of that particular attribute? ENGINEERED-BY
Thanks again for the help
"AVI_TB_INFO_B" <----- Block name
"ENGINEERED-BY" <-------------- Attribute TAG
"ENGINEER NAME" <------------ String to replace
This time save the file as you see it here within the code tags. run upon loading but maintaining the sub-function for you to able use in thefuture.
(defun brown (bn tg os ns / ss i e ) (if (setq ss (ssget "_X" (list '(0 . "INSERT")'(66 . 1) (cons 2 (strcat bn ",`*U*"))))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (cond ((and (Eq (strcase (vla-get-effectivename e)) (strcase bn)) (foreach itm (vlax-invoke e 'GetAttributes) (if (and (eq (vla-get-tagstring itm) (strcase tg)) (eq (strcase (vla-get-textstring itm)) (strcase os))) (vla-put-textstring itm ns)))))) ) )(princ) ) (brown "AVI_TB_INFO_B" "ENGINEERED-BY" "ENGINEER NAME" "BROWN")
BUT if you are going to use this exclusively for the info you provided [HARD-CODED] this will run upon loading as well [save this as another file if you will.
(if (setq ss (ssget "_X" '((0 . "INSERT")(66 . 1) (2 . "AVI_TB_INFO_B,`*U*")))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (cond ((and (Eq (strcase (vla-get-effectivename e)) "AVI_TB_INFO_B") (foreach itm (vlax-invoke e 'GetAttributes) (if (and (eq (vla-get-tagstring itm) "ENGINEERED-BY") (eq (strcase (vla-get-textstring itm)) "ENGINEER NAME")) (vla-put-textstring itm "BROWN")))))) ) )
Question: if the string is not "ENGINEER NAME" what then? leave it as it is?
HTH
@tsbrown wrote:
.....could you make it so what ever value it will change to the new value.........How do I make this into a lisp so I can just type brown into the command line....
(defun c:brown (/ ss i e ) (vl-load-com) (if (setq ss (ssget "_X" '((0 . "INSERT")(66 . 1) (2 . "AVI_TB_INFO_B,`*U*")))) (repeat (setq i (sslength ss)) (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)) ))) (if (Eq (strcase (vla-get-effectivename e)) "AVI_TB_INFO_B") (foreach itm (vlax-invoke e 'GetAttributes) (if (eq (vla-get-tagstring itm) "ENGINEERED-BY") (vla-put-textstring itm "BROWN"))) ) ) (princ "\n<<<No AVI_TB_INFO_B blocks found>>>>") )(princ) )
HTH
@devitg wrote:Why not to use ATTOUT , fix the file as need, and then attin ??
Why not? simply put. one too many user interaction. besides i assume the datas on the block are not always the same for every drawing file.
If i had known from the get-go the exact needs of the OP i wouldnt have posted all those codes and give the OP what he wants from the start :D, serves me right over thinking the condition for a simple task.
Anyhow, someone else might find a use for those snippets
Cheers
