^C^C-layer;m;VPORT;c;81;;p;n;VPORT;;_vports
^C^C-layer;m;VPORT;c;81;;p;n;$M=$(if,$(eq,$(getvar,tilemode),0),^C^C_-vports _p,^C^C^P(ai_viewports_alert)^P)
A long time ago I had made a button with the above macro (actually there are two buttons there) to basically make a viewport and always put it in a specific layer with a specific color etc.. Well since then I've discovered I'd like to make that same viewport locked as part of the command so that when I initially draw the viewport it is locked. I am not good with code and I know I didn't make that second one as that is way beyond me.
Is there a way to code a locked viewport without picking on it or typing in a name so that I basically click my command button and draw my viewport and when I am done everything in my macro up above is done and the viewport is locked? Does anyone have anything like this ?
Solved by smaher12. Go to Solution.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
The following will create your layer, with the viewport on that layer, and then lock the viewport...
^C^C-layer;m;VPORT;c;81;;p;n;VPORT;;VPORTS;\\VPORTS;LOCK;ON;LAST;;
