Load lisp form lisp
2 REPLIES 2
golf32902
543 Views, 2 Replies
Load lisp form lisp
Ok I dont know if anyone had tried this but I would like to try this..
Im looking for a way to load lisp form a lisp.
;;; This lisp is to load all lisps.
(defun c:Loadlisp1 ()
  (if (not (tblsearch "XXXXXXXXX" "XXXXXX"))   ;This is to search is the lisp is already loaded.
    (progn
      (prompt "n\Arch_Undeter.vlx")
      (load "X:\\Staff\\Jon Young TEMP\\Auto CAD\\AutoCAD Add-ons\\Lisp Routains\\Arch_Undeter.vlx")
    )     ;progn
  )     ;if
2 REPLIES 2
Kent1Cooper
in reply to: golf32902
      (load "....\\Arch_Undeter.vlx")
If that's a "separate-namespace" VLX routine, you should be able to use the (vl-vlx-loaded-p) function.  Otherwise, I'm not sure how to check, except that I don't think (tblsearch) can do it [see the list of valid table names under (tblnext)].
Kent Cooper, AIA
Moshe-A
Golf Hi,
this is not the way to do it
if you have the source lisp file and you can look inside to see the function names.... than
suppose you have lisp file called mylib.lsp and inside there is function there called (myfunc)
you can do something like this:
(if (null myfunc)
 (load "mylib")
if you got a fas / vlx file then you need know at least one function name inside
otherwise it is more complicated cause you need the list of loaded lisp files (applications)
search here for APPLOAD (i recall we disscused about this a few years ago) the appload
function holds the application list (lsp + fas + vlx + mnl + arx) and this (i think) maybe found
in registry
cheers
moshe
”Boost
