List command dumping to text file locally.
11 REPLIES 11
Message 1 of 12
elfert
1116 Views, 11 Replies
Need a lisp that could dump the values of a list command in a text fil placed in a folder C:\user121\list.txt.
Thx
Best regards.
11 REPLIES 11
Message 2 of 12
pbejse
in reply to: elfert
Thx
Best regards.
look into
LOGFILEON
LOGFILENAME
LOGFILEMODE
LOGFILEPATH
QAFLAGS <-- 2
Message 3 of 12
aqdam1978
in reply to: elfert
Hi elfert,
try this one:
(defun c:List2TXT ( / e)
  (vl-file-delete (getvar "logfilename"))
  (setvar 'Qaflags 2)
  (command "_Logfileon")
  (setq e (car(entsel "\nPlease Select Just One Object!:")))
  (command "_list" e "")
  (vlax-dump-object (vlax-ename->vla-object e) t)
  (command "_LogfileOff")
  (setvar 'Qaflags 0)
  (startapp "Notepad" (getvar "Logfilename"))
Qaflags:
1     : ^C in menu macro cancels grips (acts like keyboard <Esc>).
2     : no pause during text screen listings.
4     : no "alert" dialogs (text display instead).
128 : accepts "screen picks" (point lists) via (command) function.
512 : sets Bind type to insert in R14
hope to help you 🙂
Also, Special thanks to Pbejse 🙂
Abbas,
Message 4 of 12
hmsilva
in reply to: elfert
Thx
Best regards.
my attempt...
(defun c:MyList ( / A DUMP FILE FILEUSER FOPEN FOPEN1 ITM LINE LOGF NUM OLDLOGFILE OLDQAFLAGS REST SS STR)
  (if (and (findfile "C:\\user121")
	   (setq a (car (entsel "\nSelect an object to list: ")))
	   );; and
    (progn
      (setq OldLogFile (getvar 'logfilemode)
	    OldQaflags (getvar 'QaFlags)
      );; setq
      (setvar 'logfilemode 1)
      (setvar 'QaFlags 2)
      (setq file (getvar "logfilename"))
      (command "_.list" a "")
      (graphscr)
      (setvar 'logfilemode OldLogFile)
      (setvar 'QaFlags OldQaflags)
      (if (setq fopen (open file "r"))
	(progn
	  (while (setq line (read-line fopen))
	    (if	(> (strlen line) 0)
	      (setq logf (cons line logf))
	    );; if
	  );; while
	  (close fopen)
	);; progn
      );; if
      (if (setq fileuser "C:\\user121\\list.txt")
	(progn
	  (setq	rest (member "Select objects: " logf)
		num  (- (length logf) (length rest))
		itm  1
	  );; setq
	  (while (< itm num)
	    (setq str  (nth itm logf)
		  dump (cons str dump)
		  itm  (1+ itm)
	    );; setq
	  );; while
	  (setq fopen1 (open fileuser "a"))
	  (write-line "" fopen1)
	  (foreach x dump
	    (write-line x fopen1)
	  );; foreach
	  (close fopen1)
	);;progn
      );; if
    );; progn
    (prompt "\nOr you didn't select an object, or you don't have the \"C:\\user121\" directory...")
  );; if
  (princ)
);; MyList
HTH
Henrique
Message 5 of 12
Lee_Mac
in reply to: hmsilva
My version:
(defun c:mylist ( / *error* cnt dir lgf lin rfd sel tar val var wfd )
    (setq tar "C:\\user121\\list.txt") ;; Target list file
    (defun *error* ( msg )
        (if (= 'file (type rfd))
            (close rfd)
        (if (= 'file (type wfd))
            (close wfd)
        (if (and (= 0 (cadr val)) (setq lgf (findfile (getvar 'logfilename))))
            (vl-file-delete lgf)
        (mapcar 'setvar var val)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
            (princ (strcat "\nError: " msg))
        (princ)
    (if
        (and
            (setq cnt 0)
            (= 1 (getvar 'logfilemode))
            (setq rfd (open lgf "r"))
        (progn
            (while (read-line rfd) (setq cnt (1+ cnt)))
            (setq rfd (close rfd))
    (if (setq sel (ssget))
        (progn
            (setq var '(cmdecho logfilemode qaflags)
                  val  (mapcar 'getvar var)
            (mapcar 'setvar var '(0 1 2))
            (command "_.list" sel "")
            (graphscr)
            (cond
                (   (not
                        (or (vl-file-directory-p (setq dir (vl-filename-directory tar)))
                            (vl-mkdir dir)
                    (princ (strcat "\nUnable to create target directory: " dir))
                (   (not (setq lgf (findfile (getvar 'logfilename))))
                    (princ "\nUnable to locate log file.")
                (   (not (setq rfd (open lgf "r")))
                    (princ "\nUnable to open log file for reading.")
                (   (not (setq wfd (open tar "w")))
                    (princ "\nUnable to open target list file for writing.")
                (   t
                    (repeat (+ 5 cnt)(read-line rfd))
                    (while (setq lin (read-line rfd)) (write-line lin wfd))
            (*error* nil)
    (princ)
Message 6 of 12
hmsilva
in reply to: Lee_Mac
As usual, nice one Lee!
Just one note, if Logfile exists, all content is copied to list.txt... Smiley Wink
Cheers
Henrique
Message 7 of 12
Lee_Mac
Thank you Henrique! Smiley Happy
Are you sure?
EDIT: Do you mean if LOGFILEMODE=0 and the log file exists?
Message 8 of 12
hmsilva
yes...
Message 9 of 12
Lee_Mac
Fixed:
            (close rfd)
            (close wfd)
        (if (and (= 0 cnt (cadr val)) (setq lgf (findfile (getvar 'logfilename))))
        (princ)
    (if
        (and
            (setq cnt 0)
        (progn
        (progn
            (graphscr)
            (cond
                (   (not
                            (vl-mkdir dir)
                (   t
                    (repeat (+ 2 cnt)(read-line rfd))
            (*error* nil)
    (princ)
Message 10 of 12
hmsilva
@Lee_Mac wrote:
Fixed:
Great thinking!
Nicely done, Lee.
Cheers
Henrique
Message 11 of 12
Lee_Mac
@hmsilva wrote:
@Lee_Mac wrote:
Fixed:
Great thinking!
Thanks Henrique! Smiley Happy
Message 12 of 12
hmsilva
You're welcome, Lee. Smiley Happy
It's always a pleasure to see a code so well coded!
Henrique
”Boost
