Visual LISP, AutoLISP and General Customization
List combination with common attribute
3 REPLIES 3
Iraklis2009
294 Views, 3 Replies
Hello everybody,
From what I'll say you'll understand that I have the solution right before my eyes... I am so so stuck right now.
I have two lists with lists inside:
((A) (A) (A) (B) (B) (B) (B) (C) (C))
and
((A 1) (A 2) (A 3) (B 1) (B 2) (B 3) (B 4) (C 1) (C 2))
I just want to make a list with lists that is:
((A 1 2 3) (B 1 2 3 4) (C 1 2))
I am guessing mapcar and lambda should come into play but i can't figure it out.
Any solution is more than welcome.
Thank you.
3 REPLIES 3
Lee_Mac
in reply to: Iraklis2009
Perhaps a 'GroupByAssoc' function:
(defun LM:GroupByAssoc ( l / a r )
    (while l
        (setq r
            (if (setq a (assoc (caar l) r))
                (subst (cons (car a) (append (cdr a) (cdar l))) a r)
                (cons  (car l) r)
            l (cdr l)
    (reverse r)
Example:
_$ (LM:GroupByAssoc '((A 1) (A 2) (A 3) (B 1) (B 2) (B 3) (B 4) (C 1) (C 2)))
Iraklis2009
in reply to: Lee_Mac
Dear Lee_Mac,
Kudos to you.
Worked like a charm.
A mile thanks.
Just a question.
Is there any reason I should reverse the list? - apart from having it in the original order.
Lee_Mac
You're very welcome!
Iraklis2009 wrote:
Just a question.
I assume you refer to the final expression in my function: (reverse r)?
This is to return the result in the correct order, since the list 'r' is constructed in reverse using the cons function. The reverse / cons combination is used since it is far faster than append to achieve the same result.
Lee
”Boost
