Hi were using AutoCAD 2012,
Im trying to insert an x-ref using lisp the lisp works fine till I come up to the "attach External Reference"dialogue box how do I automate the dialogue box options to be taken along with in the lisp?
(defun C:test() (setq MYPOINT MYDIST1) (setq MYPOINT (getpoint "\nselect an insertion point")) (command "x-ref" "attach" "C:/ICT/AutoCAD_Architecture_suite_2012/CUSTOM/TREADSTONE/XREFS/GEBERIT/650-270-00-1.dwg" "650-270-00-1" "A" MYDIST1 "" "") )
Solved by pbejse. Go to Solution.
I'm sorry i cant get futher then the following:
(defun C:test4() (setq MYPOINT MYDIST1) (setq MYPOINT (getpoint "\nselect an insertion point")) (command "_-xref" "attach" "C:/ICT/AutoCAD_Architecture_suite_2012/CUSTOM/TREADSTONE/XREFS/GEBERIT/650-270-00-1.dwg" "" MYDIST1 ) )
then it all goes pear shaped with warings of Xref "650-270-00-1" has already been defined?
actually skip that i se where I'm getting the hickup from. i cant workout though why it wont accept my scale input? which i want to have as standard a scale of 1:1??
@The_Caddie wrote:I'm sorry i cant get futher then the following:
(defun C:test4 ()
"_Scale"
(command
"_-xref"
"attach"
"1"
MYPOINT
Whats the deal with the variable MYDIST1?
EDIT: i see now MYDIST1 variable is the scale
(defun C:test4 ()
(command
"_-xref"
"attach"
"_Scale"
MYDIST1
MYPOINT
hello , how to add insertion coordinates to this lisp routine ?
thank you
(setq MYPOINT (list X Y Z))
that works , thanks a lot
sorry but where i can mark (accept as solution) ? 😛
i cant find it
