I need to make a lisp routine to draw a mound (mound_2004.dwg), it is saved in 2004 dwg format. Red lines are lines you have and grey lines are lines lisp routine needs to draw.
I have writen some part of lisp (mound.lsp), but have stoped at place where I need to find points on outer line. I wonder if here are some lisp functions to do it ( like this functions: vlax-curve-getPointAtDist, vlax-curve-getClosestPointTo), or I need to make one. I was looking here for functions. But could not found any or could not understand how to use it.
Solved by devitg. Go to Solution.
You can use the vlax-curve-getFirstDeriv obj param
(vlax-curve-getFirstDeriv curve-obj param)
It give the tan as SIN/COS at the point given by PARAM , it return a 3 value list , one is the SIN the other is COS
You have to deal with it , at last you can get the angle perpendicular to the curve at such point
Then you have to make a line , search for it´s intersection points with the outer poliline by IntersectWith
search for more instruction at the VLIDE HELP .
Get the distance between both points , and make the new line related with the wide at such point .
Works, but not finished
(vl-load-com) (setq GDISTANCE 5) (setq GOSNAP_VAR 0) (setq GLAYER 0) (setq GLAYER_NEW "Slaitas") (setq GORTHOMODE 0) (defun da_ChangePropertes ( / ) (setq GOSNAP_VAR (getvar "osmode")) (setq GLAYER (getvar "clayer")) (setq GORTHOMODE (getvar "orthomode")) (setvar "osmode" 0) (command "_layer" "m" GLAYER_NEW "") (setvar "orthomode" 0) ) (defun da_ReturnPropertes ( / ) (setvar "osmode" GOSNAP_VAR) (setvar "clayer" GLAYER) (setvar "orthomode" GORTHOMODE) ) (defun da_FixCoordinates (coords base_pt / first pt0 pt1 pt2 temp_coords) (setq temp_coords (list)) (while (/= coords nil) (setq pt0 (list (car coords) (cadr coords))) (setq coords (cdddr coords)) (setq temp_coords (append temp_coords (list pt0))) ) (list temp_coords) ) (defun da_GetPolylineData (/ polyline_name) (setq polyline_name (car (entsel))) (if (= (cdr (assoc 0 (entget polyline_name))) "LWPOLYLINE") (setq polyline_name polyline_name) (setq polyline_name "0") ) ) (defun da_GetPolyline (msg error_msg / polyline) (setq polyline "0") (while (= polyline "0") (princ msg) (setq polyline (da_GetPolylineData)) (if (= polyline "0") (princ error_msg) (vlax-ename->vla-object polyline) ) ) ) (defun da_GetPointsOnPolyline (ent_name / segment return_data count coord temp_list) (setq coord (vlax-get ent_name 'Coordinates)) (setq count 1) (setq segment 0) (setq return_data (list)) (setq temp_list (list (angle (list (car coord) (cadr coord)) (list (caddr coord) (cadddr coord))))) (setq coord (cddr coord)) (while (/= count nil) (setq segment (+ segment GDISTANCE)) (setq count (vlax-curve-getPointAtDist ent_name segment)) (if (/= count nil) (if (> (vlax-curve-getDistAtPoint ent_name (list (car coord) (cadr coord))) segment) (setq temp_list (append temp_list (list count))) (progn (setq return_data (append return_data (list temp_list))) (setq temp_list (list (angle (list (car coord) (cadr coord)) (list (caddr coord) (cadddr coord))) count)) (setq coord (cddr coord)) ) ) (princ) ) ) (setq return_data (append return_data (list temp_list))) ) (defun da_Intersect (basept angle_in polyline_name / line_name coords) (setq coords (list)) (while (/= basept nil) (command "line" (car basept) (polar (car basept) (- angle_in 1.570796325) 1) "") (setq line_name (entlast)) (command "extend" (vlax-vla-object->ename polyline_name) "" line_name "") (command "extend" (vlax-vla-object->ename polyline_name) "" (list line_name (car basept)) "") (setq coords (append coords (da_FixCoordinates (vlax-invoke polyline_name 'IntersectWith (vlax-ename->vla-object line_name) acExtendNone) (car basept)))) (setq basept (cdr basept)) (command "erase" line_name "") ) (setq coords coords) ) (defun da_FindCoordinatesProc (point1 point2 ac / ab x3 y3) (setq ab (distance point1 point2)) (setq x3 (/ (* (- (car point2) (car point1)) (* ab ac)) ab)) (setq y3 (/ (* (- (cadr point2) (cadr point1)) (* ab ac)) ab)) (list (+ (car point1) x3) (+ (cadr point1) y3)) ) (defun da_DrawLine (coords / line_coords pt1 pt2 faze) (setq faze 1) (while (/= coords nil) (setq line_coords (car coords)) (setq pt1 (car line_coords)) (setq pt2 (cadr line_coords)) (setq coords (cdr coords)) (if (= faze 1) (progn (command "line" (da_FindCoordinatesProc pt1 pt2 0.9) (da_FindCoordinatesProc pt1 pt2 0.1) "") (setq faze 2) ) (progn (command "line" (da_FindCoordinatesProc pt1 pt2 0.7) (da_FindCoordinatesProc pt1 pt2 0.3) "") (setq faze 1) ) ) ) ) (defun C:mound ( / middle_line_name outer_line_name middle_line_coordinates outer_line_coordinates) (setq GLAYER_NEW "Pylimas") (da_ChangePropertes) (setq GDISTANCE (cond ((getint (strcat "\nEnter distance: <" (rtos GDISTANCE 2 0) ">: "))) (GDISTANCE))) (setq middle_line_name (da_GetPolyline "\nSelect middle line. " "\n Error: not polyline.")) (setq outer_line_name (da_GetPolyline "\nSelect outer line. " "\n Error: not polyline.")) (setq middle_line_coordinates (da_GetPointsOnPolyline middle_line_name)) (setq outer_line_coordinates (list)) (while (/= middle_line_coordinates nil) (setq outer_line_coordinates (append outer_line_coordinates (da_Intersect (cdar middle_line_coordinates) (caar middle_line_coordinates) outer_line_name))) (setq middle_line_coordinates (cdr middle_line_coordinates)) ) (da_DrawLine outer_line_coordinates) (da_ReturnPropertes) (princ) ) (prompt "\n Enter \"mound\" to start program.") (princ)
YOU PROGRAM IS THE BEST ALGORITHM & PROGRAM
JUST I CONVERT TO C+ADS
IF YOU NEED CONERT YOUR SOURCE INTO C++ARX OR C# ,PLEASE SEND TO ME THE PRIVATE MESSAGE
AFTER I CONVERTED YOUR SOUCE INTO C+ADS,
THEN I WILL SEE THE SOURCE BEATIFUL IN C#
[CODE]
HERE IT IS YOUR PROGRAME:
(defun da_ChangePropertes ( / rr)
/c2s: GOSNAP_VAR=getvar("osmode"); // HERE IT IS THE PROGRAMMING LANGUAGE" VIRTUAL C+LISP"
GLAYER=getvar("clayer"); // AFTER THE COMPILATION -> RESULT 100% LISP
GORTHOMODE=getvar("orthomode");
setvar("osmode",0);
command("_layer","m",GLAYER_NEW,"");
setvar("orthomode",0);
rr)
(Defun da_DrawLine (coords / line_coords pt1 pt2 faze rr)
/c2s:
faze=1;
while(coords != nil)
{ line_coords=car(coords);
pt1=car(line_coords);
pt2=cadr(line_coords);
coords=cdr(coords);
if (faze == 1)
{ command("line",da_findcoordinatesproc(pt1,pt2,0.9),da_findcoordinatesproc(pt1,pt2,0.1),"");
faze=2;
} ; else
{ command("line",da_findcoordinatesproc(pt1,pt2,0.7),da_findcoordinatesproc(pt1,pt2,0.3),"");
faze=1;
rr)
(defun da_FindCoordinatesProc (point1 point2 ac / ab x3 y3 rr)
/c2s: ab=distance(point1,point2);
x3= ( ( (car(point2)-car(point1))* (ab*ac))/ab);
y3= ( ( (cadr(point2)-cadr(point1))* (ab*ac))/ab);
rr=lISt( (car(point1)+x3), (cadr(point1)+y3));
rr)
(defun da_FixCoordinates (coords base_pt / rr first pt0 pt1 pt2 temp_coords)
/c2s: temp_coords=lISt();
{ pt0=lISt(car(coords),cadr(coords));
coords=cadddr(coords);
temp_coords=append(temp_coords,lISt(pt0));
rr=lISt(temp_coords);
rr)
(Defun da_GetPointsOnPolyline (ent_name / rr segment return_data count coord temp_list)
/c2s: count=1;
segment=0;
return_data=lISt();
while(count != nil)
{ segment= (segment+GDISTANCE);
count=vlax.curve_getpointatdist(ent_name,segment);
if (count != nil)
return_data=append(return_data,lISt(count));
else terpri();
rr=return_data;
rr)
/c2s: polyline="0";
while(_tcscmp(polyline,"0") ==0)
{ princ(msg);
polyline=da_getpolylinedata();
rr=(_tcscmp(polyline,"0") ==0)?princ(error_msg):
vlax_ename2vla_object(polyline) ;
rr)
(Defun da_GetPolylineData (/ polyline_name)
/c2s: rr=car(entsel());
if (cdr(assoc(0,entget(rr))) == "LWPOLYLINE")
rr=rr ;
else
rr="0";
rr)
(Defun da_Intersect (basept angle_in polyline_name / line_name coords)
/c2s: coords=lISt();
while(basept != nil)
{ command("line",car(basept),polar(car(basept), (angle_in-1.570796325),1),"");
line_name=entlast();
command("extend",vlax.vla_object->ename(polyline_name),"",line_name,"");
command("extend",vlax.vla_object->ename(polyline_name),"",lISt(line_name,car(basept)),"");
coords=append(coords,da_fixcoordinates(vlax.invoke(polyline_name, "$ 'IntersectWith",vlax.ename->vla_object(line_name),acExtendNone),car(basept)));
basept=cdr(basept);
command("erase",line_name,"");
rr=coords;
rr)
(defun da_ReturnPropertes ( / rr)
/c2s: setvar("osmode",GOSNAP_VAR);
setvar("clayer",GLAYER);
setvar("orthomode",GORTHOMODE);
rr)
//ByA: Shinigami_black
%fopen(_pathuser("inc\lspfn_startvar.h"));
(setq GDISTANCE 5)
(setq GOSNAP_VAR 0)
(setq GLAYER 0)
(setq GORTHOMODE 0)
%fclose();
(Defun pp_asdk_mound( / rr middle_line_name outer_line_name middle_line_coordinates outer_line_coordinates)
/c2s: dfn_cmd_browser(2);
GLAYER_NEW="Pylimas";
da_changepropertes();
GDISTANCE=cond(getint(strcat("\nEnter distance: <",rtos(GDISTANCE,2,0),">: ")),nil;gdistance);
middle_line_name=da_getpolyline("\nSelect middle line. ","\n Error: not polyline.");
outer_line_name=da_getpolyline("\nSelect outer line. ","\n Error: not polyline.");
middle_line_coordinates=da_getpointsonpolyline(middle_line_name);
outer_line_coordinates=lISt();
while(middle_line_coordinates != nil)
{ outer_line_coordinates=append(outer_line_coordinates,da_intersect(cdar(middle_line_coordinates),caar(middle_line_coordinates),outer_line_name));
middle_line_coordinates=cdr(middle_line_coordinates);
da_drawline(outer_line_coordinates);
da_returnpropertes();
terpri();
dfn_cmd_browser(3);
rr)
[/CODE]
Will it increse speend of program?
I programm becouse I want to have more experience in programing and I hate to do manual work, which requires a lot of time and produce little results.
