Visual LISP, AutoLISP and General Customization
Valued Mentor
sthompson1021
Message 1 of 2 (850 Views)
Lisp routine for page setup
850 Views, 1 Replies
01-09-2013 01:44 PM
Hi, as the title says I found a lisp routine on the internet to change page setups on multiple layouts. The lisp worked but on some of the layouts it moved the viewport off the paper background (see attached). The layouts print fine but the only way to get the viewport back on to the background is to open the page setup and click modify, then ok and close. I tested this on a .dwg that I had saved to my computer rather then on one in  the main folder but I would like to do this to to all are maps since our IT decided to rename our printer and now all pages setups are no good.All I know about lisp is how to run one. Could someone try this out and see if it works for them or maybe see whats wrong with the code?
;; Copy current layout page setup to all layout tabs
(vl-load-com)
(defun c:CPS (/ Adoc Layts clyt)
  (setq aDoc  (vla-get-activedocument (vlax-get-acad-object))
 Layts (vla-get-layouts aDoc)
 clyt  (vla-get-activelayout aDoc)
  (foreach
     itm
        (vl-remove (vla-get-name clyt) (layoutlist))
    (vla-copyfrom (vla-item Layts itm) clyt)
  (princ)
*Expert Elite*
braudpat
Message 2 of 2 (780 Views)
Re: Lisp routine for page setup
01-18-2013 08:59 AM in reply to: sthompson1021
Hello
I am using often this nice routine MPL coming from a french forum www.cadxp.com (Author: Patrick_35)
Attention: MPL.lsp + MPL.dcl
so you have to copy these 2 files into your native AutoCAD folder
or add the path (where are these 2 files) to the SUPPORT of your AutoCAD ...
Bye, patrice
Bye, Pat
You are not logged in.
Announcements
Need installation help?
Ask the Community
