I cannot get my lisp routine to run when I batch plot in AutoCAD 2014. It's loaded into the startup suite and runs when I open the individual drawings but not during a batch plot. How can I get this to run during a batch plot? Any suggestions?
I am working on a lisp program for batch plotting from laout, and i want to plot all files without opening them.
in above context any one can provide me lisp routine for the same.
From what I can tell, the Publish command ignores the S::STARTUP that would run on a normal open.
I have a routine that fires if a special .TXT file is found in the DWG folder. If it exists, it swaps out our disclaimer block with an architectural seal and sets the issue date...
When we switched to ACA 2012, it stopped working. My workaround was to make a custom menu and place the "trigger" lisp code in an MNL file that loads with a custom menu... That loads my .LSP file and runs the routine for me if PUBLISH is underway.
