Visual LISP, AutoLISP and General Customization
Lisp problem inserting Attributes
2 REPLIES 2
138 Views, 2 Replies
We have a Lisp routine that we are trying to run in AutoCAD2000. The Lisp
routine should bring up the attribiute dialogue box, however the commands
only appear on the command line.
Below is a copy of the Lisp routine we are using.
(defun c:test ()
(command "attdia" "1")
(command "insert" "c:/temp/a1text" "0,0" "1" "1" "0")
Any ideas or help please !!
regards
Si Morton
2 REPLIES 2
Try inserting the block without specifying the attributes, then call ddatte
with the "last" entity.
(defun c:test ()
(setvar "attreq" 0)
(command "ddatte" "l")
(setvar "attreq" 1)
You should have an error handeler here to make sure the attreq ssystem
variable is set back to 1.
Hope this helps.
Rune Wold
Application Designer
Engineering Systems
rune@engsys.no
"Si Morton" wrote in message
news:eeff5c4.-1@WebX.SaUCah8kaAW...
> (defun c:test ()
> regards
> Si Morton
Thanks Rune,
Thats worked
regards
Si Morton
Rune Wold wrote in message
news:eeff5c4.0@WebX.SaUCah8kaAW...
ddatte
> (defun c:test ()
> (setvar "attreq" 0)
> (setvar "attreq" 1)
> Hope this helps.
> Rune Wold
> Engineering Systems
> rune@engsys.no
Lisp
commands
> > (defun c:test ()
> > regards
> > Si Morton
”Boost
