dragonman101
Message 1 of 6 (1,487 Views)
Lisp move multiple text to line
1487 Views, 5 Replies
05-31-2012 12:52 PM
Hey guys. I have been struggling with an idea for a lisp. I have some general knowledge in lisp coding. But I can't seem to figure this one out (even to get started).
What I want to do is make a lisp that:
 - selects a line
then
 - select any amount of text (any type)
then
 - moves all the text to that selected line without rotating the text
if a line is perfectly horizontal then move the text of the y axis.
if the line is vertical then move the text of the x axis.
or there can be a prompt asking the user to chose the angle or axis in which the text will move (say if they want to move the text to a slanted line, you can choose to move the text on an angle, while keeping the same format and not rotating the text, or you can ask the user if they want to move it only vertically or horizontally)
I hope this wasn't too confusing.
I would really like the code to integrate into my autocad
Please  let me know if you have any questions about my request.
Thank you very much
See pictures
Distinguished Mentor
_Tharwat
Message 2 of 6 (1,466 Views)
Re: Lisp move multiple text to line
05-31-2012 02:24 PM in reply to: dragonman101
Hope this help ..... :smileyhappy:
(defun c:test (/ l ss i sn v p e) (vl-load-com)
;;; Tharwat 31. May. 2012 ;;;
  (if (and (setq l (car (entsel "\n Select Line :")))
           (eq (cdr (assoc 0 (entget l))) "LINE")
           (progn
             (prompt "Select texts to move to selected line")
             (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
    (repeat (setq i (sslength ss))
      (setq sn (ssname ss (setq i (1- i))))
      (setq v (vlax-ename->vla-object sn))
      (setq p (vlax-curve-getclosestpointto
                l
                (cdr (assoc 10 (entget sn)))
      (if (eq (cdr (assoc 0 (setq e (entget sn)))) "MTEXT")
        (progn
          (entmod (subst (cons 71 2) (assoc 71 e) e))
          (vla-put-insertionpoint v (vlax-3d-point p))
        (progn
          (vla-put-alignment v acAlignmentTopCenter)
          (vla-put-TextAlignmentPoint v (vlax-3D-point p))
  (princ)
____________________________________________________
Get learn and learn and practice , to become experienced guy .
pbejse
Message 3 of 6 (1,448 Views)
05-31-2012 08:43 PM in reply to: dragonman101
(Defun c:MoveText  (/ li txts e)
      (if
            (and (princ "\nSelect Line for Alignment")
                 (setq li (ssget "_+.:smileyfrustrated::E" '((0 . "*LINE"))))
                 (princ "\nSelect Texts to Align")
                 (setq txts (ssget "_:L" '((0 . "TEXT,MTEXT")))))
                 (repeat (sslength txts)
                       (vla-move
                             (setq e (vlax-ename->vla-object
                                           (ssname txts 0)))
                             (vla-get-insertionpoint e)
                             (vlax-3d-point
                                         (ssname li 0)
                                         (vlax-get e 'insertionpoint)))
                       (ssdel (ssname txts 0) txts)
      (princ)
HTH
dragonman101
Message 4 of 6 (1,430 Views)
06-01-2012 04:46 AM in reply to: pbejse
Thank you so much, this work perfectly!!!
dragonman101
Message 5 of 6 (1,425 Views)
06-01-2012 04:48 AM in reply to: _Tharwat
thank, this is very helpful, however it does not work with plines and didn't quite line up the text the way I wanted.
Very close though.
No need to tweek it however. I have the solution now.
_Tharwat
Message 6 of 6 (1,419 Views)
06-01-2012 04:53 AM in reply to: dragonman101
Very close though.
You showed into your aim image that the texts are located on the line at the center of each text . Am I right ?
And for polyline , it is too simple to add to codes .
You are not logged in.
Ask the Community
