I have a lisp routine that I am using to move a detail next to another then move it again to leave a speace between the two. What I need is a routine that will repeat this function until the user presses Enter or Escape keys.
Solved by gccdaemon. Go to Solution.
Dumb question. Should have googled first.
(defun C:DETAILMOVE (\ GP1) (while (setq GP1 (getpoint "Pick LOWER LEFT corner of detail [press ENTER to exit]: ")) (C:DTLMOVE) ) (princ) ) (princ)
