Lisp file to give texts a background,
It would be great if there is a lisp file that”
thank you
best
Jamal
Why not use the bring text to the front and then use the TEXTMASK command?
Gerald....
Thanks Gerald,
My intent here is to give proiority for texts wherever they are:
What is hoped is
Best
Jamal
With all these wipeouts everywhere under every text/att element in the file, will your recipients see any lines below for the construction? I think you are asking for something that will create more issues since it may encourage you to not focus on each location for easier fixes (like moving them out etc.).
BTW, you'll have to redefine all your blocks and place wipeouts behind the attributes fo you have them ALL the time, as opposed to mixing and matching haves-have notes in your drawings and symbols libraries.
Same with your dimstyles, mleaderstyles and mtext objects: define them as you want in your templates so you don't mix up various attributes in many files of a single project. That leads to many more mistakes down the road (unless your entire project is housed in one single DWG file of course).
Thanks Sadallah,
Since the AutoCAD is not able to manage labels conflicts between labels themselves or with other objects as the ArcGIS) does (knowing that ArcGIS is a different platform), for example.
Then I would prefer to give priorities to texts everywhere on the drawing because this is what is supposed to be read by the user. Conflicts between labels and objects/other labels will produce very confusing maps with multiple overlaps and thus several of these texts will be hard to be read and thus no use of the drawing information.
Thanks mkweaver. That could work in particular cases
Best
Jamal
Jamal,
for the above example, dimensions, you do not need a lisp, on the Dimension Style Editor, on the Text tab, select Background for Fill Color...
hope that helps
Henrique
Many thanks Henrique for the answer,
That’s for sure! The dimension has the option! How about multiline text style? Leader style?
What I meant is to have an automated lisp that brings all the text above regardless where they are (text in dimensions, text in leaders, text is fields, etc.)
Best
Jamal
Many thanks pbejse,
What I wanted is to have a lisp that can recognizes whatever text in the drawing and give it that property (white background + bring to front)!
Text can be in:
Best
Jamal
As far as i can tell , Your question was asked and answered. The thing is, you need to put it all together.
Many thanks pbejse,
What is offered is not integrated the manner I wanted it to work. This is why I needed a help considering the that fact that I’m not a developer and couldn’t play with codes.
Very much appreciated
Best
Jamal
you know Jamal, not everyone uses a white background -- so 'white' really doesn't work as a generic approach. Frankly, white is IMHO a poot choice -- to much noise hiding the signal. You're welcome to it, but....
