Visual LISP, AutoLISP and General Customization
Lisp file to give texts a background,
14 REPLIES 14
Message 1 of 15
JamaL9722060
882 Views, 14 Replies
It would be great if there is a lisp file that”
  1. manages to give all the texts (dimension text, leader text, attributes, regular text, text in blocks, fields, etc.) a WHITE background. This is quite essential since the text should not be overlapped with other objects and must be read easily on the plan
  1. sends all text (dimension text, leader text, attributes, regular text, text in blocks, fields, etc.) to front
thank you
best
Jamal
Jamal Numan
14 REPLIES 14
Message 2 of 15
in reply to: JamaL9722060
Why not use the bring text to the front and then use the TEXTMASK command?
Gerald....
Message 3 of 15
JamaL9722060
Thanks Gerald,
My intent here is to give proiority for texts wherever they are:
  1. Attributes
  2. Fileds
  3. In blocks
  4. Single text
  5. Multiline text
  6. Diemsnion text
  7. Leader text
What is hoped is
  1. To give them white background
  2. To bring them to front
Best
Jamal
Jamal Numan
Message 4 of 15
pendean
With all these wipeouts everywhere under every text/att element in the file, will your recipients see any lines below for the construction? I think you are asking for something that will create more issues since it may encourage you to not focus on each location for easier fixes (like moving them out etc.).
BTW, you'll have to redefine all your blocks and place wipeouts behind the attributes fo you have them ALL the time, as opposed to mixing and matching haves-have notes in your drawings and symbols libraries.
Same with your dimstyles, mleaderstyles and mtext objects: define them as you want in your templates so you don't mix up various attributes in many files of a single project. That leads to many more mistakes down the road (unless your entire project is housed in one single DWG file of course).
Message 5 of 15
JamaL9722060
in reply to: pendean
Thanks Sadallah,
Since the AutoCAD is not able to manage labels conflicts between labels themselves or with other objects as the ArcGIS) does (knowing that ArcGIS is a different platform), for example.
Then I would prefer to give priorities to texts everywhere on the drawing because this is what is supposed to be read by the user. Conflicts between labels and objects/other labels will produce very confusing maps with multiple overlaps and thus several of these texts will be hard to be read and thus no use of the drawing information.
Jamal Numan
Message 6 of 15
mkweaver
You might consider adding tranparecy to your mask. I've been using 30% which seems to produce a decent compromise between not being able to read the text And not being able to see the underlying linework.
Message 7 of 15
JamaL9722060
in reply to: mkweaver
Thanks mkweaver. That could work in particular cases
Best
Jamal
Jamal Numan
Message 8 of 15
hmsilva
Jamal,
for the above example, dimensions, you do not need a lisp, on the Dimension Style Editor, on the Text tab, select Background for Fill Color...
hope that helps
Henrique
Message 9 of 15
JamaL9722060
in reply to: hmsilva
Many thanks Henrique for the answer,
That’s for sure! The dimension has the option! How about multiline text style? Leader style?
What I meant is to have an automated lisp that brings all the text above regardless where they are (text in dimensions, text in leaders, text is fields, etc.)
Best
Jamal
Jamal Numan
Message 10 of 15
pbejse
Have a look-see ->>>>  enclose text and insert wipeout all together then we will pick from there.
Message 11 of 15
JamaL9722060
in reply to: pbejse
Many thanks pbejse,
What I wanted is to have a lisp that can recognizes whatever text in the drawing and give it that property (white background + bring to front)!
Text can be in:
  1. Single text
  2. Multiline text
  3. Fields
  4. Attributes
  5. Dimensions
  6. Leaders
  7. Text in blocks
Best
Jamal
Jamal Numan
Message 12 of 15
pbejse
As far as i can tell , Your question was asked and answered. The thing is, you need to put it all together.
Message 13 of 15
JamaL9722060
in reply to: pbejse
Many thanks pbejse,
What is offered is not integrated the manner I wanted it to work. This is why I needed a help considering the that fact that I’m not a developer and couldn’t play with codes.
Very much appreciated
Best
Jamal
Jamal Numan
Message 14 of 15
jggerth
you know Jamal, not everyone uses a white background -- so 'white' really doesn't work as a generic approach.  Frankly, white is IMHO a poot choice -- to much noise hiding the signal.  You're welcome to it, but....
Message 15 of 15
JamaL9722060
in reply to: jggerth
Thank you JGerth
Best
Jamal
Jamal Numan
”Boost
