Hello!
I am very new to AutoLisp programming. I am currently using Autocad 2013 and this is my first try on writing one.
Sometimes it works great, sometimes it will only work once. I'm wondering if I am missing some basic component of a program that may cause this?
The program is suppose to insert sequential numbers, at a specified direction into a drawing. Sometimes it gets to the ".text" command but does not execute this.
I have attached the file if anyone happens to have a chance to look at it.
Thanks!
- Barb
Try it now and let me know .
(defun c:numbering (/ anno txht dir dirrad sp snum enum distpref dist temploc tempnum ) (initget "Yes No") (setq anno (cond ((getkword "\n Is text annotative? (Y/N) <N> ")) ("No") ) ) (if (null anno) (setq txht (getreal "\nEnter Text Height: ")) ) (if (= anno "No") (setq txht (getreal "\nEnter Text Height: ")) ) (initget "0 90 180 270") (setq dir (getkword "\nEnter dirction of text from first entry in degrees (0,90,180,270) " ) ) (princ "Direction chosen is: ") (princ dir) (princ) (cond ((= dir "0") (setq dirrad 0)) ((= dir "90") (setq dirrad (/ pi 2.))) ((= dir "180") (setq dirrad pi)) ((= dir "270") (setq dirrad (* 1.5 pi))) ) (princ "\nDirection chosen in radians is: ") (princ dirrad) (princ) (initget 1) (setq sp (getpoint "\nPick middle point of first text entry: ")) (setq snum (getint "\nEnter start number: ")) (setq enum (getint "\nEnter end number: ")) (initget "P E") (setq distpref (getkword "\nWould you like to give distance by picking 2 points (P) or entering a number (E)? <P or E> " ) ) (cond ((= distpref "P") (setq dist (getdist "\nPick 2 points on screen: ")) ) ((= distpref "E") (setq dist (getreal "\nEnter distance between middle of text positions: " ) ) ) ) (setq temploc sp) (setq tempnum snum) (repeat (+ 1 (- enum snum)) (cond ((= anno "No") (command "_.text" "m" "_none" temploc txht 0 tempnum) ) ((= anno "Yes") (command "_.text" "m" "_none" temploc 0 tempnum) ) ) (setq temploc (polar temploc dirrad dist)) (setq tempnum (1+ tempnum)) ) )
That works fabulously! 🙂 I'm going with it.
I noticed you changed the following
- How I got if the text was annotative
- The command ".text" to "_.text" and added "_none"
Do you have feel if which one of these may have cause the problem? (Meaning caused to program to act goofy after an inital run.)
Thanks for your help!
Just a couple of suggestions, baberndt:
(if (null anno) (setq txht (getreal "\nEnter Text Height: "))) (if (= anno "No") (setq txht (getreal "\nEnter Text Height: ")))
could be replaced with:
(if (/= anno "Yes") (setq txht (getreal "\nEnter Text Height: ")))
and:
(cond ((= distpref "P") (setq dist (getdist "\nPick 2 points on screen: "))) ((= distpref "E") (setq dist (getreal "\nEnter distance between middle of text positions: "))) )
(setq dist (if (= distpref "P") (getdist "\nPick 2 points on screen: ") (getreal "\nEnter distance between middle of text positions: ") ); ends if );ends setq
Also the last "cond" statement test whether anno = "yes" or "no" but it could be nil. Might want to replace (= anno "No") with (/= anno "Yes")
(if ("mysolution"=answer) then (click "Accept As Solution"))
@baberndt wrote:Do you have feel if which one of these may have cause the problem? (Meaning caused to program to act goofy after an inital run.)
No , actually there is something very important in the begining of the routine that you did not notice , read the code
once again .
Hint "anno" variable .
So you know.
All this:
(initget "P E") (setq distpref (getkword "\nWould you like to give distance by picking 2 points (P) or entering a number (E)? <P or E> ")) (cond ((= distpref "P") (setq dist (getdist "\nPick 2 points on screen: "))) ((= distpref "E") (setq dist (getreal "\nEnter distance between middle of text positions: "))) ) ; closes cond
to
(setq dist (getdist sp "\nPick 2 points or Enter distance between middle of text positions on screen: "))
Another way to write the code
(defun c:numbering (/ anno txht dirrad sp snum enum dist temploc tempnum ) (if (zerop (cdr (assoc 40 (tblsearch "STYLE" (getvar 'textstyle))))) (setq txht (initget 1) txht (getreal "\nEnter Text Height: ")) ) (initget 1) (setq sp (getpoint "\nPick middle point of first text entry: ")) (initget 1) (setq dirrad (getangle sp "\nPick point for direction")) (princ (Strcat "Direction chosen is: " (angtos dirrad 0))) (initget 1) (setq snum (getint "\nEnter start number: ")) (initget 1) (setq enum (getint "\nEnter end number: ")) (initget 1) (setq dist (getdist sp "\nPick 2 points or Enter distance between middle of text positions on screen: " ) ) (setq temploc sp) (setq tempnum snum) (repeat (+ 1 (- enum snum)) (command "_.text" "m" "_non" temploc) (if txht (command txht) ) (command 0 tempnum) (setq temploc (polar temploc dirrad dist)) (setq tempnum (1+ tempnum)) ) (princ) )
HTH
Was bored today and wanted to offer something new
Try this ...
(defun c:Test (/ no st nd sp p pt rpt ang hop gap gr lst) (defun *error* (x) (if lst (foreach x lst (entdel x)) ) (princ "*Cancel*") ) (defun _T (st nd pt sp ang / no e lst) (setq no st) (repeat (1+ (- nd st)) (setq e (entmakex (list '(0 . "TEXT") (cons 10 pt) (cons 11 pt) (cons 1 (itoa no)) (cons 40 (getvar 'textsize)) (cons 7 (getvar 'textstyle)) '(50 . 0.) ) ) ) (setq lst (cons e lst)) (setq pt (polar pt ang sp) no (1+ no) ) ) lst ) (if (and (if (not (not (eq 4 (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (getvar 'CLAYER))))))))) (progn (alert "Current layer is LOCKED <!> ") nil) t ) (setq st (getint "\n Speficy START number :")) (setq nd (getint "\n Speficy END number :")) (if (> st nd) (progn (alert "START number must be smaller than the END number <!>") nil) t ) (setq sp (getdist "\n Specify gap distance :")) (setq pt (getpoint "\n Specify base point :")) ) (progn (setq rpt (1+ (- nd st)) ang 0. hop (* pi 0.25) ) (setq lst (_T st nd pt sp 0.0)) (while (or (eq (car (setq gr (grread t 15 0))) 5) (eq (cadr gr) 9)) (redraw) (princ "\r *** Press TAB to have new prompt ***") (if (eq (cadr gr) 9) (progn (setq gap sp p pt no st ) (if lst (foreach x lst (entdel x)) ) (if (equal ang (+ pi pi)) (setq ang (* pi 0.25)) (setq ang (+ ang hop)) ) (setq lst (_T st nd pt sp ang)) ) ) ) ) ) (princ "\n Written by Tharwat Al Shoufi") (princ) )
Tharwat
Great to see the different approaches! Best training around - try it yourself and then see how the pros do it 🙂
