If they were blocks with attributes it would be much easier.
I am thinking is it possible scale everything from basepoint A by factor N, then use a lisp to move everything along individual polar direction from basepoint A, by a certain distance as result calculated with N and Distance between object and basepoint A?
I'Im not able to develop LIPS program, earlier I received this mail from our group. if this may help to develop, please try.
A Donut is a two-semi-circular-arc-segment Polyline forming a circle, with a constant non-zero width. You could have a routine find all Donuts this way:
{code}
(setq donuts
(ssget "X"
(0 . "LWPOLYLINE")
(-4 . "")
(-4 . "!=") (43 . 0.0)
(90 . 2)
); end filter list
); end ssget
); end setq
{code}
The (42 . 1.0) with its NOT surroundings will see Polylines with bulge factors *only* for full semi-circle arc segments [Donuts have two each like that, and none with other values]. The (43 . 0.0) with its not-equal prefix will find only those with a global width, but one that is not zero. The (90 . 2) will find only those with exactly two vertices. [If you might have any Donuts that are "heavy" 2D Polylines (made with PLINETYPE=0), you'll have to do other things to find them.]
To change the size of each of them in place, if the "ID point" is at the center, you'd need to *calculate* their center points to use as Scale base points, because they are not part of the entity data. If 'ent' is a Donut's entity name from the selection set, this is one way to get its center point, halfway between its two vertices:
{code}
(mapcar '/
(mapcar '+
(vlax-curve-getPointAtParam ent 0)
(vlax-curve-getPointAtParam ent 1)
); end inner mapcar
'(2 2 2)
); end mapcar
{code}
A start....
Kent Cooper
@kumaran123 wrote:Dear Friends, I have several donuts and blocks with id points. (SEE THE ATTACHED DRG) I need to change all donuts size together and ID point should be the same. similarly the text also to be changed globally with same ID. can anyone send me a lisp for this operation. thanks a lot ( see the attached Drg for your reference) ALSO nee to insert new DONUT or similar blocks at purticulat coordinates. thanks & appreciate
What we need to see is the before and after kumaran123
