• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Active Member
    Lisp Modification
    342 Views, 3 Replies
    12-02-2010 07:58 AM
    We have a lisp routine that places a vertical line in front of text and mtext.  I want to start using the multi-leader command instead of a customized leader.  Can anyone take a look at our routine and offer suggestions on modifying it so it can work with multi-leaders?  The lsp file is attached.
    Please use plain text.
    Distinguished Contributor
    Re: Lisp Modification
    12-02-2010 12:48 PM in reply to: gbarfield
    replace
    (COMMAND "LINE" ....
    with
    (COMMAND "MLEADER".... or whatever you want to use in place of "line"
    Active Member
    12-02-2010 01:45 PM in reply to: andrew.nao
    Should anything be done to the line near the beginning that is listed below?  Should anything about multi-leader be put in there?
    (SETQ ITEMS (SSGET '((0 . "TEXT,MTEXT")))); revised to only get text
    Active Member
    12-03-2010 06:07 AM in reply to: andrew.nao
    Maybe I didn't make myself clear with my first question.  If I make the change that you suggested, it'll draw a multileader in front of the text and not a line.  I still want a line in front of text, but I want to be able to select multi-leader text as well as text and mtext.
